Go to Post And now you know why we have a " No Karthik singing zone " north of the border. - Steve W [more]
Unread 03-03-2016, 15:01
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Analog Gyro .getAngle() function occasionally giving massive random values
We're working in java, and we're running into an issue with our gyro. Occasionally we get large position spikes from the .getAngle() function. Not sure why. We're using the gyro in between threads, could it be an issue with the .getAngle() not being thread safe? I noticed that we don't (I think) get spikes in the main thread that the roborio runs by default, we only get spikes in other threads. It's been really annoying to debug because it only happens like once a minute or so.
I posted to Programming rather than to Java to see if this was an issue not just specific to java. I also can post code if needed, but for the most part it's fairly straight forward code. I was wondering if anyone has seen anything similar, or knows about things like this.
Thanks for any help in advance.
But why?
Unread 03-03-2016, 15:19
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: Analog Gyro .getAngle() function occasionally giving massive random values
Look at your electrical connections. Analog Gyros will give some crazy numbers if they don't have a good connection.
I might be wrong here, but when you have no radial velocity, the analog gyro should output 2.5V, then increase or decrease depending on which way it's rotated.
If the connection isn't good, the controller won't see 2.5V and will give you widely varying numbers like what you're seeing.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 03-03-2016, 17:12
Maxwell777's Avatar
AKA: Jackson Gray
I might be wrong here, but when you have no radial acceleration, the analog gyro should output 2.5V, then increase or decrease depending on which way it's rotated.
I've replaced the gyro, and it's still acting the same. Overall, the gyro acts normal, has a bit of drift and measures rotation fairly accurately, but every so often it'll spike, but still return to where it should be. I suspect it's software because (iirc) the gyro feeds us rate, and if we were to get a voltage spike, I doubt we'd read the same value as before the spike.
But why?
Unread 03-03-2016, 20:12
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
What about the wire going from the RoboRIO to the gyro? Are the connections good on the wire? Is it running next to any power wires for things like motors/batteries?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 03-03-2016, 20:52
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Java AnalogGyro.getAngle() is indeed NOT thread-safe as currently written. If you are calling it from multiple threads with no locking protection you can get corrupted results. I'll get a patch submitted that adds "synchronized" to the various AnalogGyro methods, but in the meantime you can add locking yourself around all calls to AnalogGyro and see if that fixes the problem for you.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 04-03-2016, 00:11
Maxwell777's Avatar
AKA: Jackson Gray
Thanks! I'll try that out. I figured that .getAngle() was thread safe because it returned a primitive type and I didn't think that there was anything too crazy running in the background. Do you know if any other common wpilib stuff that isn't thread safe? I might start going around and locking everything I can lol
But why?
Unread 04-03-2016, 02:56
WPILib Developer
Generally speaking, it should be thread-safe except for setup-type functions. E.g. it's not safe to call gyro calibrate() in a separate thread from gyro getAngle(). That said, most robot code doesn't use threads outside of PIDController so there are probably other places where locking may have been missed.
