| Thread Tools |
Rating:
Display Modes |
#16
Re: 2220's Play/Record Macro for Autonomous
Cool stuff, glad to hear a python team did it first..
In 2003, the first year that FIRST had autonomous modes, I was a senior in high school and I implemented this exact same type of thing that year in PBASIC. Only had 22k of flash memory to write to though... but it worked like a champ! |
#17
Hey, take this to worlds with ya, ok?
#18
Just an update for those still interested in this- after some debugging, the entire setup should be much more stable now, hope that the changes will help.
#19
Thank you and Team DNA for this awesomeness. Do you mind if i work on making a universal version of this?
#20
One of the most clever things I've seen yet. Nice work.
#21
In most cases, I am terrible at writing an autonomous sequence, but it is in this case that I believe I can get a firm grasp of the concept. |
#22
I'm also interested in this program as well. I requested access to view the Drive folder.
#23
I wrote something like this a while ago, and I've got a little bit of advice.
During a competition, any periodic functions aren't exactly constant. Their timing may change, especially on a field, as it waits for data from the Driver Station. To remedy this, use something like a 'heartbeat' thread, that triggers on a constant rate, all the time (for us, we use 50hz). This means you don't get the next data point at an inconsistent rate, which causes jerking in driving and/or any other mechanisms. Other than that, it looks good . Good luck in Autonomous! |
#24
Jaci - Did you just use a timer in your thread to pace the reads and writes, or some other triggering mechanism? Thanks!
#25
EDIT: Whoops, i misunderstood. We do reads and writes as we go along. Since the RIO non-volatile storage is flash, we've tested that just reading from a BufferedReader is fast enough to not cause hickups |
#26
Thank you!
#27
We did this last year, but wound up not using it due to inconsistency of the motor values due to battery charge. Since a motor running at a speed of, lets say, 0.8 runs at different speeds depending on the charge of the battery. This causes the autonomous, depending on the battery charge, to look right, but wind up not driving/turning the correct distance. How did you guys tackle this problem? Do you incorporate encoders and/or a gyroscope?
#28
Oh yeah, we're something similar this year (sensor data PIDs with an autonomous mapping/design program). I'm just curious to see if the play/record macro did something to fix the inaccuracy of using motor speed values, since it would wind up being quite annoying to deal with for the teams using it.
#30
