Go to Post Not joining as a freshman was the worst mistake I have ever made. - ProgramLuke [more]
Unread 04-03-2016, 11:28
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Drilling holes to reduce frame weight: best pattern
We are reducing the weight by drilling into our 1"X4" hollow, rectangular Al tubing (1/8" thick-walled). Two questions:
  1. What would the best spacing pattern (i.e. square grid, diamond, circular, etc.?)
  2. What would the largest structurally "safe" diameter be?
Unread 04-03-2016, 11:33
Re: Drilling holes to reduce frame weight: best pattern
Can you please provide a photo of the actual component you are trying to cut weight from? Without that we cannot really tell what safe pocketing looks like.
However, in most cases, myself and others would recommend attempting to replace the current structure with thinner walled material, if possible.
Unread 04-03-2016, 11:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
2. Depends on the loading, eh?
I'd start with big holes, because they actually reduce weight. But they don't reduce it by much. If you drill a dozen 3" diameter holes in 1/8" thick material, you'll get rid of a pound of aluminum. You'll need 26 2" diameter holes to get that same pound. The smaller the holes, the worse it gets.
I'd be seriously looking at other things to change, and drill holes in the frame as a last resort. But that's because I'm naturally lazy.
Unread 04-03-2016, 11:36
Agreed - hardware is where you can trim down a lot. Look for areas where bolts are longer than they need to be, areas where small screws/bolts can be replaced with rivets (or even epoxy in some cases), superfluous wires and cables that don't need to be as long as they are, etc.
Unread 04-03-2016, 11:41
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Aluminum nuts for 1/4-20 exist and have been used by us. Saves a surprising amount of weight if you have a lot of fasteners.
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 04-03-2016, 12:00
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
1> circles are better than squares/diamonds (usually) due to stress risers.
2> before we can truly answer this we need to know the amount of force expected on the part and the direction of the expected force.
___________________
- Tennyson, Ulysses
Unread 04-03-2016, 12:11
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
best bit to use is a step drill
best to use a pilot hole
Staggered center pattern is easy. Allows up to 70 percent open
McMaster 8841A34
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 04-03-2016, 12:14
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I agree with the posters that say round holes are best. Also, smaller holes are better for stress (but the same for weight if you remove the same square inches), they'll affect buckling loads less.
I've had good luck making 1 to 1-1/2 inch dia holes with a conduit punch--they look nicer than any drill and they go quickly. You mentioned diamond, so maybe you're intending on NC machining
Also, all of the people worried about strength, I can't think of many areas where you need the amount of strength a 1 x 4 x 1/8" aluminum rectangular section will provide. But I don't know your loading.
Another way to shave weight from such a section would be to thin it using a table-saw with an aluminum blade. This would have the least effect on stress, less than any holes.
Another note: if the tube sees mostly bending, remove holes or thin evenly. across the faces. If the tube sees lots of torsion (twisting), remove more toward the corners and leave the centerline of each face intact. Highest stress in torsion is down the center axis of the face.
Unread 04-03-2016, 12:36
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I'll agree with what I see above except this. A step bit is like a crescent wrench - one tool does a lot of different stuff, but doesn't do any of it as well as the right tool does. Using a step bit requires grinding up every bit of aluminum in the hole, increasing time, energy, and waste. If you are going to drill more than a few holes of a given size, get an appropriate hole saw. Faster, neater, less swarf, and most of the aluminum you remove can be tossed in the recycle bin in one piece. I have also noticed step bit holes tend to "wander" off the intended location farther than hole saw holes, especially if drilled in a hurry.
Unread 04-03-2016, 12:51
MrForbes's Avatar
AKA: Jim
I second the hole saw recommendation. Notice I started by suggesting 3" holes....
Unread 04-03-2016, 13:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
[Sardonic Irony] You don't have a 3" step bit? [/sardonic irony]
Unread 04-03-2016, 15:08
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
One of the easier ways to drop weight is to switch from CIMs to Mini-CIMs. You can drop 0.6 lbs. a motor. The two have very similar torque at 40 amps, the Mini-CIM just doesn't have as high of a stall torque.
Might be easier than drilling that many holes in your frame.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 04-03-2016, 15:46
Jalerre's Avatar
Jalerre Jalerre is offline
FRC #4965 (FIRE)
Jalerre is on a distinguished road
You're going about this all wrong. To reduce weight don't drill holes, shorten the code. The less lines of code, the lighter the robot. 1s weigh more than 0s.
Vex
2013: 415 - Fabrication, Programming, Electrical
2014: 415D - Captain, Programming Lead
FTC
2014: 7354 - Programming Lead
FRC
2013: 415 - Safety Animation, Fabrication
2014-2015: 4965 - Programming & Electrical
2016: 4965 - Captain, Programming Lead, Electrical
Unread 04-03-2016, 16:14
Are you sure about that? In the Flash memory I am familiar with, programming a memory cell removes electrons from its gate.
It's similar to Hollerith cards and paper tape that way -- adding code removes material.
Unread 04-03-2016, 16:21
Jalerre's Avatar
FRC #4965 (FIRE)
Didn't know that. Nevermind then, increase the code.
Maybe I can use this as an excuse to get my hands on the robot from the mechanical team.
Vex
FTC
FRC
