Go to Post I'm throwing the Unnecessary Sarcasm Flag here. - Joe Johnson [more]
Unread 04-03-2016, 12:51
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Drilling holes to reduce frame weight: best pattern
I second the hole saw recommendation. Notice I started by suggesting 3" holes....
Unread 04-03-2016, 13:32
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
[Sardonic Irony] You don't have a 3" step bit? [/sardonic irony]
Unread 04-03-2016, 15:08
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
One of the easier ways to drop weight is to switch from CIMs to Mini-CIMs. You can drop 0.6 lbs. a motor. The two have very similar torque at 40 amps, the Mini-CIM just doesn't have as high of a stall torque.
Might be easier than drilling that many holes in your frame.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
