Go to Post We're not behind, the rest of the world is ahead! Yeah. Thats it. - Curtis Williams [more]
Unread 05-03-2016, 14:43
Re: How do I program with an Andymark AM-2314?
Originally Posted by VersionTwo View Post
We are trying to use an AM-2314... Does anyone know ... how to implement the code for it?
You might try contacting this person:
Originally Posted by nickbrickmaster View Post
I'm trying to use the ITG3200 gyro on the AndyMark breakout board (am-2314). I translated some code I found from Java... The gyro works in Java using the original
Unread 05-03-2016, 19:59
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
We have some Java source code available for the ITG-3200 using an I2C chip out at github that you are welcome to experiment with:
https://github.com/frc868/frc868-lib...ds/lib/sensors
It might work with gyro portion of the AM-2134, but we have not tried it.
You would need both the GyroAdapter.java and ITG3200.java source files. The basic usage is described in the class javadoc (basically you create an instance and then use one of the getGryoX(), getGryoY or getGyroZ() methods for each axis you want to monitor).
