Go to Post If FIRST isn't your life, then you're doing something wrong! - BandChick [more]
Unread 05-03-2016, 18:41
TheOnyxReaper TheOnyxReaper is offline
FRC #2357
TheOnyxReaper is a glorious beacon of lightTheOnyxReaper is a glorious beacon of lightTheOnyxReaper is a glorious beacon of lightTheOnyxReaper is a glorious beacon of lightTheOnyxReaper is a glorious beacon of light
3D Printable Electrical Wire Clip
Hey teams! We've designed a few 3D printable parts that work with the RoboRIO. The parts are made to hold the wires you put into the PWM, DIO, Analog and Relay ports in place during the Robot's movement. They are fastened with simple zip-ties and when properly attached will hold the wires in place very well. The parts are available on Thingiverse at http://www.thingiverse.com/thing:1380606. Feel free to use these on your robots!
https://drive.google.com/file/d/0B-9...ew?usp=sharing
