Go to Post Nothing worse than an intolerant field :D - JB987 [more]
Unread 03-05-2016, 11:29 AM
VersionTwo VersionTwo is offline
FRC #1405
VersionTwo is an unknown quantity at this point
Question How do I program with an Andymark AM-2314?
We are trying to use an AM-2314, but cannot find the API for it. Does anyone know where the API is, or at least how to implement the code for it?
-ayy
Unread 03-05-2016, 02:10 PM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: How do I program with an Andymark AM-2314?
Did you look for accelerometer, and gyro functions? I seem to recall those being in wpilib. There is not a 2314 lib
Unread 03-05-2016, 02:43 PM
Originally Posted by VersionTwo View Post
We are trying to use an AM-2314... Does anyone know ... how to implement the code for it?
You might try contacting this person:
Originally Posted by nickbrickmaster View Post
I'm trying to use the ITG3200 gyro on the AndyMark breakout board (am-2314). I translated some code I found from Java... The gyro works in Java using the original
Unread 03-05-2016, 07:59 PM
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
We have some Java source code available for the ITG-3200 using an I2C chip out at github that you are welcome to experiment with:
https://github.com/frc868/frc868-lib...ds/lib/sensors
It might work with gyro portion of the AM-2134, but we have not tried it.
You would need both the GyroAdapter.java and ITG3200.java source files. The basic usage is described in the class javadoc (basically you create an instance and then use one of the getGryoX(), getGryoY or getGyroZ() methods for each axis you want to monitor).
