Go to Post It's up to veteran teams and mentors to help keep the original spirit of FIRST alive. - It's up to us to make these boards exemplify the FIRST principals in every post. - Ben Mitchell [more]
Unread 05-03-2016, 20:35
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Open Flame in the Pits
Why is this not allowed? How else are teams expected to prevent fraying cords and ropes. Obviously you could use tape, but it isn't nearly as professional or permanent as burning the end. I think it's a stupid rule. I get that the rule helps to prevent fires in the pit and things like that, but these teams are trusted with many more dangerous tools and equipment than a lighter.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 05-03-2016, 20:41
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Open Flame in the Pits
Originally Posted by Ginger Power View Post
Why is this not allowed? How else are teams expected to prevent fraying cords and ropes. Obviously you could use tape, but it isn't nearly as professional or permanent as burning the end. I think it's a stupid rule. So Chief Delphi, tell me why I'm stupid for thinking this.
If open flames were allowed in the pit then time is added into the safety theater encounters that I do so loathe. I'm fine with the tape. It is weird though that someone hasn't made a monopoly out of a flame free solution to this problem.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 05-03-2016, 20:43
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Can't you use an old soldering iron?
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 05-03-2016, 20:49
jaunvie jaunvie is offline
FRC #5090
jaunvie is an unknown quantity at this point
Yes a sodering iron will work fine for rope or webbing. You can also get a special "hot knife" designed for that purpose. Like this one
Unread 05-03-2016, 20:51
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Very good advice. Will consider this for the future.
Unread 05-03-2016, 21:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Based on what I've seen from many teams, with regards to their work habits and work environment in the pits, I for one am completely in favor of the rule.
Unread 05-03-2016, 21:21
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Or soak the end in glue. Also have used heat shrink tubing.
Unread 05-03-2016, 21:23
DonRotolo's Avatar
Back to humble
FRC #0832
Emphatically seconded
Unread 05-03-2016, 21:25
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Butane powered soldering irons are also good. They usually have a hot knife bit and a hot air bit that gets melting things hot. They get around the open flame rule since they're run off a catalyst once they heat up.
As for the rule itself, I don't think there's any other power tool a team could currently use that could actually being down an entire event. Not without serious misuse. A propane torch pointed the wrong way could quickly shut the entire event down.
Unread 05-03-2016, 21:33
Michael Hill's Avatar
We've recently discovered this works great for polycord: http://www.amazon.com/858D-Station-S.../dp/B009PPRJHS
I happened to have one and brought it in. You might try it on cord or rope. But if you do get one, I HIGHLY recommend making a modification for safety's sake. They wired the neutral wire to the fuse rather than the hot, so even if your fuse blows, you still have 110V running through your unit.
Unread 05-03-2016, 21:37
philso philso is offline
FRC #2587
Yes.
Try soaking about an inch long section with superglue. When the glue is set, cut the cord with a sharp implement.
Unread 05-03-2016, 21:45
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
We have a DIY nichrome wire cutter that cuts rope for us and cauterizes the end at the same time. Great tool.
Costs about $10 to make; just a power supply and nichrome wire.
Unread 06-03-2016, 01:39
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Yeah, uh, I'm going to agree with the majority here-- while there are some teams I would trust to safely have an open flame in their pits, I'm not sure I could say that about the majority or even many teams. Heck, I'm not sure I'd trust myself to be safe with fire in the pits, and I was a scout for almost ten years. Also, consider the many teams that have big, potentially flammable banners in their pits... In close proximity to other pits... Yeah, I like the no open flames rule.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 06-03-2016, 01:40
EricH EricH is online now
And then there's the off-chance that somebody tries to fuse a rope that isn't plastic-type. Read: Is flammable, not meltable.
Not fun.
Unread 06-03-2016, 01:47
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Still not legal as they require an open flame to start up. Otherwise, they'd be great for pit use.
