Go to Post Our robot throws custom $5.50 FIRST Frisbees at a rate of 75 discs per minute and a speed of ~32 feet per second. It costs over $80 to feed our robot for 12 seconds. - Woolly [more]
Unread 05-03-2016, 21:30
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Driver
whitetail is an unknown quantity at this point
Field durability
Today at Hatboro-Horsham the defenses started to actual get damaged pretty seriously, some even had to be brought to the machine shop for repair. I am wondering if this is happening at other events or not?
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590 and 2607)
2016 MAR Hatboro-Horsham District event Winner(Thanks 2607 and 1218)
Unread 05-03-2016, 21:31
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Field durability
Long answer
yes
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 05-03-2016, 21:38
Chase Haddleton's Avatar
Chase Haddleton Chase Haddleton is offline
Software Mentor
FRC #3683 (Team D.A.V.E.)
Rookie Year: 2015
Chase Haddleton is an unknown quantity at this point
Depends on what defenses you're talking about.
At GTCR this past few days the low bars were abused quite a bit (both the fabric hanging off of it, and the mounting of the bar to the base), and the portcullis was broken once (I believe it was only once).
Other than those two defenses, I don't think anything broken/damaged to the point of being repair.
The defenses, walls, and batters did get marked up quite a bit, though nothing beyond scuffs and scratches (from what I saw).
Unread 05-03-2016, 21:42
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
At Hatboro I saw a shovel the fries break (saw it being repaired in the machine shop), the rock wall come out of the base and fly into the courtyard, and a portcullis come crashing down as a robot tried to traverse it. And that's just from being there for an hour and seeing Instagram posts so I'm sure there were more problems. At the end of the night the field was behind schedule by almost an hour and a half!
EDIT: Just talked to a friend competing at Hatboro and the field ended 1 hour and 47 minutes behind schedule (10 matches postponed until tomorrow). One of their matches was restarted 5 times! The field was utterly destroyed
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 05-03-2016, 21:48
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Waterford, many matches played without access to the Fries... started with Match 1... We also finished the weekend with no fabric on the low bars...
The sooner we get behind schedule, the more time we have to catch up.
Unread 05-03-2016, 21:54
longilive longilive is offline
FRC #0321
longilive is an unknown quantity at this point
At Hatboro a lot of games were restarted (sometimes multiple times) due to defenses coming loose, such as the rock wall, moat, portcullis. Also, a sally port was almost destroyed (pieces were falling off), but that was mostly because the team was ramming the sides of it (not the actual door).
The defenses coming lose was the main issue though. A lot of teams method of getting over defenses was by running into them hard so it happened a lot.
Unread 05-03-2016, 22:02
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
at duluth the drawbridge took the beating. we ended up using the ones from the practice fields. one robot went straight through it braking it in half horizontally
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 05-03-2016, 22:17
Sirdickey's Avatar
Sirdickey Sirdickey is offline
We Dem Bois
AKA: Asad Siddiqui
FRC #6152 (ROBOFALCONS)
Rookie Year: 2016
Sirdickey is an unknown quantity at this point
Our robot actually dug six nice holes in the tower's challenge plastic at Waterford!
Unread 05-03-2016, 22:31
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
At Waterbury, the rough terrains were getting bent and stuck in their places on the field. It took 20 minutes to get one out. Also, the sally port has taken a beating. Part of the side wall keeps flying off a lot. More than once, we shall say. Otherwise, everything's pretty good.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 05-03-2016, 22:38
HannahF's Avatar
HannahF HannahF is offline
Laced in a Legacy
FRC #0433 (The Firebirds)
HannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant futureHannahF has a brilliant future
I was a ref at Hatboro Horsham and I can confirm that all of our defenses took quite a beating and that we had more than our fair share of field faults due to robots dislodging defenses.
Here are some of my personal favorites. (Note all pictures were taken after the field fault was called):
http://www.chiefdelphi.com/media/photos/43020?
http://www.chiefdelphi.com/media/photos/43019?
http://www.chiefdelphi.com/media/photos/43018?
I guess these defenses just weren't built #MARtough
FIRST is like family and now my Family does FIRST!!
[2008-2011] Firebirds 433 Student, Head of Programming, Vice President
[2013-2015] Bambiebotz 4637 College Mentor
[2015-Present] Firebirds 433 Mentor, Strategy and Design
Unread 06-03-2016, 01:14
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
At SD there was field fault (comm) issue and replay next day
Also I saw then "taping" the field in eliminations
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 06-03-2016, 01:16
EricH EricH is online now
Had a field problem in elims, too. Seems somebody took out a side panel when they were coming out of the low bar to the neutral zone. Foghorn, replay...
Unread 06-03-2016, 01:24
Tmeziere's Avatar
Tmeziere Tmeziere is offline
AKA: Tim
FRC #3021 (The Agency)
Team Role: Driver
Tmeziere is an unknown quantity at this point
This was the case. Team 2486 the coconuts took a 3 foot piece of the wall out.
Unread 06-03-2016, 05:30
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
Also, we've seen the same problems with the low bar fabric, and there have apparently also been holes getting gouged out on the carpet.
Unread 06-03-2016, 06:38
Gdeaver Gdeaver is offline
FRC #1640
HH has big problems. Way behind. If this continues could be a real problem for teams and their transportation arrangements. First has to find an alternative for those pins.
