Real defenses are nothing like the wood versions
This was brought up in a buried post in a thread from week 0, but after just completing our first event I thought it was important to bring it up.
The real defenses are NOTHING like the wood versions. If you can, I would highly recommend buying some HDPE sheet and covering your wood defenses with it. With our wood defenses, our robot crosses them like they're not even there. With the real defenses, we had some real troubles crossing them. The friction is so different that we had to come up with some new techniques for crossing. I knew it would be different, but we didn't realize how much. Be warned. The portcullis on the other hand was much easier on the real field. |
Re: Real defenses are nothing like the wood versions
That's always an issue every year. the teams with the most resources have entire real fields. a fair middle ground of teams Frankenstein their own field elements together to get as close to the real one but still staying reasonable about it and then those who either don't know better or don't have the resources build what's in the team drawings.. which is always so significantly different it's almost pointless, but still better than nothing.
Oddly enough since the only experience we had with field elements was off of a scrimmage we went to nearing the very end of building, our robot that was practically just kit of parts actually did better with some of the defenses than at the scrimmage
In what ways do the metal defenses behave differently?
They are much harder as in wood is soft and forgiving metal is not. The moat was fairly easy in the wood version the metal was kill our bot.
Its also sort of bad at regionals because the practice field is wood too so it is not close to the field. (and very crowded)
Basically if you can do it on wood that is no guarantee it will work on the field..even the batter, bots were losing traction on. Our tank treads did awesome, many wheeled bots struggled/got stuck/tipped etc. Last edited by Boltman : 06-03-2016 at 01:25. |
#7
After just reading these short few replies I have such mixed feelings for the GDC and this years games.
Per the manual landing page... Quote:
The GDC tried so hard to make this game fair and playable to all levels this year... ...And then we go and shovel fries so hard in week 0.5 that the production process gets re designed. |
#8
Hey teams in Dallas, 1296 has "real" defense elements. You are welcome to come try them! PM me.
HTH |
#9
It comes down to the wooden team version being very soft and also providing a different coefficient of friction for treads/tracks/belts/etc. Definitely a learning experience for me. |
#10
As mentioned in the post above: friction.
Our method for climbing over the obstacles relies on enough friction to push the wheels into the obstacles (like rock wall, for instance) with enough force to create enough friction to allow the wheels to climb up and over the obstacle. On the wood version - this works perfectly. On the plastic/metal version - not so good. |
#11
As said above there is a huge difference from wood, however has anybody found a solution to the drawbridge?
It bends SO MUCH it has become impossible for our robot unless it is held down by another |
#13
Some teams can do it have to have the right mechanism or much more likely cooperate
#14
(Now if only we could do that during autonomous. ..... Next time.) |
#15
And it showed at the Palmetto Regional. We loved watching Mittens the robot fly through the outer works. As I recall you guys had some motor trouble in semi finals? I am sorry that you had to lose that way. I think it is wonderful that you have these resources and are willing to share them with the other teams in your area. |
