Go to Post Life has its Ups and Downs, you can stay down or push yourself. - Mike Schroeder [more]
Unread 06-03-2016, 12:45
peterl peterl is offline
AKA: Peter Laser
FRC #1592 (Bionic Tigers)
peterl is an unknown quantity at this point
Re: Using the Xbox One controller ?
Originally Posted by sanelss View Post
Yes it works just fine both the 360 and xbox one controllers, we're using one of each ourselves. The original oem ones you just plug in and run windows update to find the driver, the after market ones you may have an issue getting the driver installed since the windows update won't recognize them so you will have to find an older installer for the driver but then that will work.
if you're using labview I can share a vi that makes them MUCH easier to use too.
That would be amazing, please share! We are having issues getting them recognized by the DS. Device Manager sees them, but the DS isn't, or is only seeing one instead of two.
