Go to Post I owe these forums a lot more than $15 for all of the help and friends they have given me. - Karibou [more]
Unread 05-03-2016, 17:19
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Coms
We keep losing coms each match when the robot hits a bump. We are not losing power to the robot. It reloads and then reloads code. If you have and suggestions we are all ears.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 05-03-2016, 17:22
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Coms
My first recommendation is to talk to the CSA or FTA at your event. They have more tools available to diagnose the issue.
Why do you think you are not losing power if your code has to reload? How long is the link down for?
Make sure to double check all wires to the roboRIO and radio and that they are seated correctly. Check the red and yellow fuses on your PDP too. You should be pushing them in until your finger hurts, then push more.
Unread 05-03-2016, 17:43
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: Coms
Ensure that your power cables to the roborio are securely fastened and not in the slightest bit loose. Earlier in the season we had the same issue and were convinced it wasn't the roborio loosing power because we would watch it and the lights never seemed to go out.
It ended up being that the roborio lost power for a 1/10th of a second and then booted back up making the lights appear to always be on. Once we reseated the roborio cables and ensured they were tight, the problem went away.
Unread 05-03-2016, 18:00
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Coms
Percussive troubleshooting is in order. For our 2014 bot, we found the bad connection by tapping the back of the electronics board in different spots with a mallet. As you tap around, watch for the problem. When you get it narrowed down to a repeatable spot, you know where to look.
If it doesn't happen with this method, tap harder.
Unread 05-03-2016, 18:58
nuggetsyl's Avatar
FRC #0025
Re: Coms
I owe you a beer or rootbeer depending on how old you are thanks.
11 VCU winner
12 MAR Mt Olive
red is for team 348
Unread 05-03-2016, 19:31
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: Coms
Tug Test all wires!
Unread 06-03-2016, 07:50
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Coms
We saw a similar thing, and found that it was with the connection between the radio's power cord and the voltage regulator. If this connection wiggles at all the radio dies. Once you have it snuggly connected (and pull tested). You may want to consider hot gluing the connections to the regulator.
Unread 06-03-2016, 13:21
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Coms
Isn't this a pretty controversial interpretation of "not modifying electrical components"? I know we've been called and had to remove hot glue before... is there something I missed?
Unread 06-03-2016, 13:30
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Re: Coms
So during bag and tag night for Team 2052 KnightKrawler whenever we went under the low bar, the top of our robot hits the bar sometimes and that caused us to lose comms. We think the shock affected the radio and we put some foam like material to absorb the shock near our d-link so we wouldn't lose comms and at lake superior we never had that issue.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 06-03-2016, 13:39
Re: Coms
Compare the 2014 R64 to the 2016 R66
Originally Posted by 2014-R64
The Driver Station software, cRIO, Power Distribution Board, Digital Sidecars, Analog Breakouts, Solenoid Breakouts,
RSL, 120A breaker, motor controllers, relay modules, Wireless Bridge, 12VDC-5VDC converter, and batteries shall not
be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring,
disassembling, etc.), with the following exceptions:
Originally Posted by 2016-R66
The Driver Station software, roboRIO, Power Distribution Panel, Pneumatics Control Modules,
Voltage Regulator Modules, RSL, 120A breaker, motor controllers, relay modules, Wireless Bridge,
and batteries shall not be tampered with, modified, or adjusted in any way (tampering includes
drilling, cutting, machining, rewiring, disassembling, etc.), with the following exceptions:
Unread 06-03-2016, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Coms
Wait a minute: Do you mean that the rules change from year to year? When did that start happening?
Unread 06-03-2016, 22:55
Re: Coms
Its not really a change. 2016 just doesn't mention gluing specifically but is arguably still included in the "etc." at the end of the rule. So while yes the words of the rule are different, the intent is possibly the same and is therefore controversial.
Unread 06-03-2016, 23:07
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Coms
2016 R66-F says adhesives are allowed to secure cables. That was not allowed by the 2014 version of the rule.
Unread 06-03-2016, 23:12
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Coms
Good! Since we went dead qual 1 and quickly secured the connections..with adhesives. Worked rest of the way.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
