pic: Bumper Handles
Re: pic: Bumper Handles
I love the idea, but I'm concerned about legality in the face of picky inspectors. That's not part of a standard bumper cross-section, nor is it attachment hardware used to attach the bumper to the frame perimeter. Your handles basically don't have anything to do with bumper functionality. You couldn't get away with attaching a sensor system or motor to your bumpers (to save weight) and claim it was part of your attachment system.
I'd Q&A those handles and have a back-up solution worked out, unless running without any handles is acceptable. |
I also love the idea. This would make loading and unloading the robot safer and easier. However, if your handles are mounted to the bumper, are your bumpers mounted to your frame securely enough to lift the robot? A good, secure bumper mount might not be load-bearing enough for this application.
Edit: That said, I concur that they do not comply with the bumper rules. The rules constructively specify that bumpers are for protection, secure attachment to the chassis, and alliance color and team number designation. Any part of the bumper that does not provide one or more of these functions should not be part of the bumper. If the same parts which fill these functions just happen to provide additional functions, that's OK, but it's hard to see how lift handles fill any of the required bumper functions. Last edited by GeeTwo : 06-03-2016 at 23:37. |
Handles are good! although you might want to attach them to the robot itself, instead of the bumpers. We try to integrate handles into our robots if possible, or attach them to the frame if we can't find an elegant place for them.
This year, they are part of the skid rails on top of the robot...if you look close, you can see the finger holes in the polycarbonate cover. ![]() |
The bumpers passed inspection this last weekend event and we used them all weekend. They were great. My view was that they make lifting the robot safer. Also if its not listed as illegal than they are legal until they say something. If they say something than we can easily remove them. We usually build the handles into our robot design but with going under the low bar it did not leave room for them. We had this Idea for last year but funny that we could not use them.
#7
With BUMPERS, it's the opposite, since R21 says "BUMPERS must be constructed as follows:". The specifications that follow make no mention of lifting handles.
#8
Bumpers are meant to act as bumpers and bumpers only. You're given a certain allowance of FREE weight and space to add bumpers to protect your robot. The rules are so strict here because there's a history of leveraging that free allowance to gain an advantage. More weight is more pushing power, so teams would make bumpers as heavy as possible. I think 3847 is responsible for the wording about not compressing the noodles. They made a set of highly compressed bumpers that probably cushioned collisions much less, but gave them a distinct advantage in pushing matches, as they would wedge under uncompressed bumpers. Just this year, the GDC almost made any velcro at all on bumpers illegal. A pointed Q&A modified that ruling to allow velcro backed by hard bumper parts, but we nearly ended up with a LOT of illegal bumpers in FRC. And so on. By your own admission, you're gaining an advantage with your bumpers unrelated to their purpose. You have handles on your robot that you otherwise wouldn't have. Yes, you may have passed an inspection with them, but "It passed at my last event." is not going to persuade an inspector that notices you have illegal bumpers. It certainly never persuaded me when I saw something illegal on a robot. Also, it's your responsibility to follow the rules to the best of your knowledge. Inspection determines gross legality, but there's any number of ways you could violate the rules and still be 99% certain to pass inspection. So. You've got a few opinions that your bumper mods aren't legal. You might want to post a Q&A to determine whether they are or not. |
#9
At the LRI Training, I discussed the need for handles on all robots with Frank as a safety issue. I think we need them and my team regularly uses either a set of fixed handles, or eyebolts in the frame that we snap lifting strap handles to. It makes controlling the robot much easier and safer and keeps the CG lower for better control. One of the other inspectors reported that he had a robot dropped on his head while sitting at the inspection station table!
With having to go over the wall to the secret passage and other elements to get on or off the field this year, lots of kids are going to be tripping while carrying robots. We need handles! Having said that, however, I believe putting them on the bumpers will get you into trouble and your inspector should not have approved them for the reasons given above, mostly that they don't meet the description of a legally constructed bumper. In addition, I think you may have created a potential for other robots to snag and get hooked on your handles since they are outside the frame perimeter. |
#10
That being said, thank you for clarifying that they can be removed easily enough. |
#11
Love the idea!
