Go to Post If you smack the bear with a stick, you'd better be ready for a mauling. - sciguy125 [more]
Unread 06-03-2016, 16:25
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Vision calibration during a competition
Hello, I was wondering when I could calibrate my vision code during a regional. Is it during the practice matches?
The reason I say is this is because it would be easier to get on the robot over usb directly on the field and download an image immediately.
If I can't do that I guess I could capture an image using a joystick button and save it.
Any help would be appreciated, thanks.
Drew
Unread 06-03-2016, 16:35
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Vision calibration during a competition
Drew
We spent about an hour on the actual field right before practice matches so say 10 ish they open on practice day with games at 12 about six bots were calibrating..we never did get out auto aim to work due to camera being obstructed by parts of our bot...we'll see if we can get it going this week...fingers-crossed
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 06-03-2016, 16:37
jreneew2's Avatar
AKA: Drew Williams
Thanks!
But just to clarify:
As in the robot on the field connected over usb?
Unread 06-03-2016, 16:38
Thanks!
We were on the field and wired to the bot not sure if it was USB
jreneew2's Avatar
AKA: Drew Williams
Thanks!
Unread 06-03-2016, 17:21
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
There is usually a field access period. Thursday morning before practice rounds start. Check the calendar for your regional.
Unread 06-03-2016, 18:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I would caution you strongly to not assume that you will have access to the fields. Create a system that will take pictures during practice matches and comptetion matches. Access to the field can be severely limited at times.
Unread 06-03-2016, 19:00
I agree that this is a good idea, but the manual guarantees 30 minutes available for measurement and calibration per section 5.5.8. It should take a very extreme circumstance to be ignoring this guarantee.
Unread 06-03-2016, 19:33
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
In the five years I've been coaching, we've had that garunteeed time actually given to us about 6 times. That's out of 13 competitions, so less than 50% of the time, you get it everytime.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 06-03-2016, 21:11
The default dashboard saves one image per second to the Documents/LabVIEW Data. If you make a custom DB, you can extend that. You can also hit the red circle on the DB to record the match video to an AVI. You can then extract images from the AVI.
Greg McKaskle
