#31
Re: FRC Spyder
What does DPR and CCWM mean or represent?
#32
Re: FRC Spyder
The Android app shows this blurb when you tap the '?' button at the top of the stats page; I'm not sure about iOS:
Re: FRC Spyder
DPR (Defensive Power Rating) uses the same mathematical model to estimate THE AVERAGE SCORE OF the opposing alliances' scores. WHETHER LOWER OR HIGHER DEPENDS LARGELY ON THE CHARACTERISTICS OF THE OPPOSING TEAMS IN THOSE ALLIANCES.
#34
Re: FRC Spyder
What a truly wonderful reason for unlimited data! Thank you for this app! Our team used it a ton today.
#35
Re: FRC Spyder
The new Android version of the app requires Google Play Services... any chance of a BB10 friendly version? (although demand is not likely very high)
Thanks for all the work you do on this app! |
#36
Re: FRC Spyder
Google Play Services isn't actually required; it's only used to receive match score notices. The app should function correctly without it. I'll see if I can change the popup to only appear once so you don't have to dismiss it every time you open the app.
#37
Re: FRC Spyder
Is it just more or are the rankings on Spyder not sorted by ranking points?
Got excited that 1675 was in 1st when they are actually in second. |
#38
Re: FRC Spyder
Predictions are generating negative scores. |
#39
Re: FRC Spyder
Re: FRC Spyder
Negative or massive OPRs (and other ratings) are just the result of not enough data. In a statistic model with up to 60 variables (teams), It takes many data points (matches) before a useful solution is available.
In short: wait a dozen matches or so |
#41
Re: FRC Spyder
Not necessarily. If a team is really struggling, the OPR at the end of the event can be negative. There was a team with negative 10 OPR in Week1.
#42
Re: FRC Spyder
You are right, if a team averages more penalties (In fouls or playing defense on their own teammates) then a negative rating can occur.
