Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
Unread 06-03-2016, 19:47
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: Legality of running a capacitor inline with roboRIO power
Originally Posted by ImOn3618 View Post
We have a rigorous standard for competition batteries, and start each machine with a fresh, fully charged battery, so I doubt that's the issue.
However, we have a very high traction drive train (brecoflex treads with about a 1.5 CoF, 750ish N force of kinetic friction while driving). The gear ratio on the drive belts is 14.2:1 using RAWboxes. While the drive train definitely contributes to our issue, there's not much we can do about it with 6hours of unbag time.
Beyond just charging them, do you do any tests on them to gauge the batteries overall health?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 06-03-2016, 19:51
ImOn3618 ImOn3618 is offline
AKA: Ethan Hammond
FRC #3618 (Petoskey Paladins)
ImOn3618 is a jewel in the roughImOn3618 is a jewel in the roughImOn3618 is a jewel in the rough
We track and compile data from a battery beak, including power output, drain rate, and changes in amperage at various voltages. If they get below a certain threshold we stop using that battery and recycle it. We've also used FRC2619's battery maintenance guide in the past.
FTC 5411: 2011-2013. FRC 3618: 2013-2017. Team Captain, CAD Wizard
Unread 06-03-2016, 19:57
That's good, should rule out a bad battery. There is a really easy solution to this problem: don't change direction really quickly.train your drivers to not do it anymore and you won't do it anymore.
Andrew Basse
Unread 06-03-2016, 20:18
...drain rate...
What are the units of "drain rate" and how do you measure it?
Unread 06-03-2016, 20:23
AKA: Ethan Hammond
It's just power output compared to ℅ battery charge. We use it to get a rough idea of how fast our batteries are being drained. Older, worse batteries tend to lose charge faster.
Theoretically, loss of 30℅ charge from 100% is normal for us. So about 12.5v to 8.75v per match, according to our multimeters
Unread 06-03-2016, 20:29
I'm still puzzling how you measure this. How do you measure power?
Unread 06-03-2016, 20:33
AKA: Ethan Hammond
It's voltage, not power(joules), my bad.
