Go to Post We also indirectly benefit from those rookie teams having well-built and working drivebases. It helps raise the level of performance across the board, making for a better competitive environment. - Alan Anderson [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 06-03-2016, 21:07
mojo371 mojo371 is offline
FRC #3950
mojo371 is an unknown quantity at this point
Week 1 statistics
With the first week of competition almost done, I decided, with all the free time and lack of a social life, to create a spreadsheet containing statistics from every regional in the first week. I did not look through every match and kept track of every breach and every shot. I took all of this data from www.thebluealliance.com.
https://docs.google.com/spreadsheets...aOje6o/pubhtml
This is the link to the spreadsheet.
If there are any problems that you may see with the data, let me know and I will fix the problem as soon as I can. Can't wait to see what will happen in the upcoming weeks and can't wait for out competition to come up. April can't come fast enough.
Unread 06-03-2016, 21:10
Torvando's Avatar
Torvando Torvando is offline
Build Team Captain
AKA: Taylor Noble
FRC #2823 (The Automatons)
Torvando is an unknown quantity at this point
Re: Week 1 statistics
It would be cool if you made a graph or graphs comparing the different regionals.
Unread 06-03-2016, 21:53
FRC #3950
Will do.
Unread 06-03-2016, 21:59
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
very cool good info good job!!
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 06-03-2016, 22:07
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Just a note, specified is spelled with a c.
Unread 06-03-2016, 23:22
cbf cbf is offline
FRC #2877
cbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nicecbf is just really nice
Your SHOOTING/TOWER scores for Northern Lights and Greater Toronto Central are identical. That seems like too much of a coincidence.
Otherwise, great job.
Really 0% Drawbridge crossings at Toronto!
Unread 06-03-2016, 23:27
Torvando's Avatar
Build Team Captain
AKA: Taylor Noble
Will do.
The graphs I assume you made are not loading for me. I don't know if this is just me or an error everyone is getting. When I trey to open them in another tab it is saying I don't have permission to get the url. Hopefully you can fix it as I was excited to see the graphs.
Unread 06-03-2016, 23:32
FRC #3950
good catch for the similar scores, Blue alliance took down the high and low goal scores so those will stay the same for now but I updated everything else. As for the graphs, I have the graphs made but have run into some troubles making sure they work in the published doc. I will try some more tomorrow to get them up.
Unread 06-03-2016, 23:57
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Eugene switched the display from total number of goals to average number of high/low goals per match. We figured that just displaying the total number didn't provide an easily comparable metric between events (since events that have wildly different match counts will have wildly different goal totals). So instead, we took the average. Hopefully this change makes the stats easier to interpret and makes it more applicable to compare results between events and over time.
Unread 07-03-2016, 00:04
FRC #3950
Thank you for letting me know. I may try and find a way to incorporate those stats into the spreadsheet.
Unread 07-03-2016, 06:54
Spoam's Avatar
Spoam Spoam is offline
AKA: Pedro M.
FRC #0955 (CV Robotics)
Spoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the roughSpoam is a jewel in the rough
Thanks for the stat dump. Did you compile these manually or via script?
2015 PNW District Champions (955, 1983, 2930)
Co-Creator of 955 OPR
Unread 07-03-2016, 07:17
FRC #3950
I manually entered in all the data for stuff like breaching success rates and climbing success rates but then used functions in excel to calculate the percentages and averages.
It wasn't that bad since www.thebluealliance.com centralized all that data for each regional under the insights tab. I just tried to centralize it more.
Unread 07-03-2016, 07:27
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
At Lake Superior, there were 202 matches played, but Class A defenses were out for 200 of the matches. (60 portcullis, 140 cdf). Was this a miscount in data, or was there a more interesting explanation at the event?
Hi!
Unread 07-03-2016, 11:01
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I've found that the TBA data has a tendency to not record defense type for position 3 in the first match. They have a few other data glitches, but that's the most common one.
Unread 07-03-2016, 12:03
Gugund Gugund is offline
BR Hu3
AKA: Luis Berger
FRC #1156 (Under Control)
Team Role: Webmaster
Gugund is an unknown quantity at this point
Could you share the editable spreadsheet or upload a downloadable version? I would like to make some graphs with all this info, using Tableau
