Originally Posted by EricLeifermann
While dropping the 1st ball helps in preventing another team from trying to steal or move the ball on the ball on the center line, it is not key to this auto.
The placement of that boulder on the center line is in a location that could hinder the other alliance from crossing a defense should they choose that, as the secret passage is directly in front and not a defense. So it comes down to do I stop them from scoring 10 points or do I score 10 points, also do I risk hitting them if we go for that ball at the same time?
Also awesome auto, though i don't think that bench grinder is a legal FRC robot.
I don't think dropping the first ball is motivated by wanting to "steal" it from the opposing alliance. They're simply putting their starting ball in a place where they have significantly more leeway on the 2nd run without getting a penalty. Why risk trying to get within 2" of a spot after crossing defenses if you can be much more reliable doing it BEFORE you cross any defenses.
1678 looked at the problem, and found a way to solve it that should be significantly less risky. If they miss the 2nd ball on the way back, oh well, but at least they're much less likely to get a penalty while doing it. Pure genius, and major kudos.
P.S. How long until you can do 3? :-P
