Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 07-03-2016, 12:50
hdurpos's Avatar
hdurpos hdurpos is offline
FRC #4980
hdurpos is an unknown quantity at this point
Scaling
Quick question, how many teams were able to scale the tower??? We (4980) successfully scaled the tower many times and I am wondering because we were the only ones at PNW West Valley that could scale.
Unread 07-03-2016, 13:17
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Re: Scaling
Four out of thirty teams were able to scale at Guilford. 3506, Yeti, was able to do it reliably; the other ones were somewhat unreliable. Our team is planning on modifying our arm to help us scale.
Unread 07-03-2016, 13:24
GCarnes's Avatar
GCarnes GCarnes is offline
FRC #5150 (Hybrid Hornets)
Team Role: Driver
GCarnes is just really niceGCarnes is just really niceGCarnes is just really niceGCarnes is just really nice
Re: Scaling
Based on this fourm: http://www.chiefdelphi.com/forums/sh...d.php?t=145323 The average scaling success rate was 3%. At the Kettering #1 District Event I remember two or three teams with successful climbers. There was maybe five or six teams that attempted scaling to various degrees of success. The team next to us in the pits actually ended up taking their entier scaling mechanism off of their robot due to it not working. My team plans on adding a scaling mechanism in the next two weeks before our second competition.
Unread 07-03-2016, 13:33
spydan's Avatar
spydan spydan is offline
Dan
FRC #0708 (Hatters Robotics)
Team Role: Marketing
spydan is on a distinguished road
Re: Scaling
Both my team (708) and Team 341 could scale at Hatboro.
www.team708.org
FLL Student: Food Factor, Senior Solutions
FRC Student: Ultimate Ascent, Aerial Assist, Recycle Rush, FIRST Stronghold
Volunteer: Ultimate Ascent, Aerial Assist, Nature's Fury (FLL), Recycle Rush, World Class (FLL), Trash Trek (FLL), FIRST Stronghold
My posts do not necessarily reflect the views & opinions of affiliated teams.
Unread 07-03-2016, 13:42
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Scaling
according to mojo371's statistics,
https://docs.google.com/spreadsheets...aOje6o/pubhtml
for the matches so far, about 2-5% of scaling opportunities resulted in a successful scale.
I expect this to improve greatly as the season progresses.
Unread 07-03-2016, 13:54
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Scaling
In San Diego we scaled 3 times all the way up as a low bot but only got credit once. first time last Q match we went up 2 seconds early... next time in QF we scored. Last time in SF we went too far up and slipped back down. Pretty much every qualification match we tried and failed as field was way different than practice wood items.
Scaling is very hard and we did not have a solution until last week ...then we tried in qualification match and finally figured it out on the actual field of play.
There were three other bots that could scale .
Its hard unless scaling is part of the bot design from the get go...for us it was a major subsystem an we worked every build week to figure it out finally had two revelations of how to do it last week (we almost didn't want to go to CV because we were struggling with it so much)...then it worked first in practice day at San Diego and should work in CV this week from our first match on.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 07-03-2016, 14:01
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
Re: Scaling
the 2% number is a really bad one. It would appear that a robot being on the field counted as an "opportunity" to scale. That is not anything close to an accurate success rate.
Warning wild guesses ahead:
From the anecdotal evidence gleaned from watching Palmetto and day 1 of the Toronto regional via live stream, the number robots that have climbers and attempted climbing is somewhere around double to triple the success rate listed in that spread sheet. From that we can GUESS that around 4-10% of robots currently intended to climb. This may change later as more and more teams start to utilize their withholding allowance to build climbers but the success rate relative to the number of total teams intending to climb will go down for a few weeks then go up during week 7 and at worlds.
