Go to Post The imbalance and vibration is telling you something, you are not listening. - Al Skierkiewicz [more]
Unread 07-03-2016, 15:47
18gbelton 18gbelton is offline
FRC #4906
18gbelton is an unknown quantity at this point
Wireless LEDs
Hi I am from Team 4906... I recently bought a wireless remote LED controller and we were wondering if it was allowed to be used at competition
Here are the LED's
http://www.amazon.com/Remote-Control...led+controller
Unread 07-03-2016, 15:55
Domtech's Avatar
Domtech Domtech is offline
I Do Everything
AKA: Dominic
FRC #2412 (Robototes)
Domtech is an unknown quantity at this point
Re: Wireless LEDs
We used a similar one once.
Our argument for why it might be legal is that it isn't a wireless communication system on its own, it is just a sensor that detects light pulses.
We would set it before going on the field and not use it during matches.
A better option we found robot-legality-wise was this:
http://www.amazon.com/HitLights-Colo...led+controller
edit:
just noticed that the one you linked uses RF wireless. that is definitely not allowed.
Our inspector a few years ago was OK with the infrared one, but I don't see them allowing that.
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Wireless LEDs
If you have some documentation about what frequency they use (probably the ~400 MHz range), you should be ok, I think. You can't use walkie talkies, and you can't set up wifi networks, but this is a totally other band. I would check with Q&A or the event FTA if you don't get a Q&A response by then. If the FTA says you can't use them, or asks you to not use them, then leave them alone.
If you're planning to use it on the robot, it's a no-go. For a stand or pit display, you should be ok with the above caveats. If it's being set once when you turn on your pit in the morning, and not touched after that, then you aren't transmitting any RF at all during the day, which should be fine.
Unread 08-03-2016, 15:41
frcguy's Avatar
frcguy frcguy is offline
#GearsAllDay
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: Wireless LEDs
I agree with what others have said. You could potentially use it in a pit display, although it does use RF for communication, so it's legality is dubious at best. If you could provide RF spectrum documentation that shows what band it operates in you might have a better shot, but it will most likely be relatively hard to find such a document. Using it on the robot is definitely not allowed however. Your best bet is probably to submit a Q&A, or just not take the risk and not use it.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
