Go to Post If you are adult enough to be a participant in this program, then you are adult enough to act like an adult. - Beth Sweet [more]
Unread 07-03-2016, 22:27
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Talon SRX in PID Speed mode won't stop!
Hi!
We have a Talon SRX (to a CIM motor, with a quadrature encoder) - it's attached via a pullup / breakout board to the encoder.
On our test robot board (no robot, just control system), it seems to behave as expected:
using control mode kSpeed - ...
(pseudo-code):
if (button1) {
talon.Set(1000.0); //turn it on.
if (button2) {
talon.Set(0.0); //turn it off.
- the talon starts and stops when commanded.
On our real bot, though, it won't stop once started.
(we also tried putting it in voltage mode; in that case
(pseudo-code):
if (button1) {
talon.Set(1.0); //turn it on.
if (button2) {
Which works fine.
Stumped!
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Unread 07-03-2016, 22:31
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to beholdPoseidon5817 is a splendid one to behold
Re: Talon SRX in PID Speed mode won't stop!
Originally Posted by mhaeberli View Post
Hi!
(pseudo-code):
if (button1) {
if (button2) {
(pseudo-code):
if (button1) {
if (button2) {
Which works fine.
Stumped!
Martin Haeberli
If you read the software reference manual, you'll see a section on how to set up speed PID control on the Talons. Based on the first step of that section, your encoder and Talon outputs are probably opposite directions. So try either:
talon.reverseOutput(true);
or
talon.reverseSensor(true);
Either of those should fix it. If it fixes it but the motor is the wrong direction, you can switch which one you are using. If for some reason it still doesn't work after that, you might want to check the roboRIO webpage and make sure you are getting encoder feedback on that Talon. Also, make sure you have the correct feedback device selected, PID parameters, etc.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
Unread 08-03-2016, 06:57
Check the web dashboard first. See if there's anything different between the two Talons' configurations, and verify that the encoder is working.
My guess is that the encoder is not working.
Unread 08-03-2016, 09:30
JPL69's Avatar
JPL69 JPL69 is offline
FRC #3596 (Rocket Robotics)
JPL69 is an unknown quantity at this point
Usually in a PID situation when a motor does not stop is due to the feedback signal is missing, or the feedback signal is reversed.
Unread 08-03-2016, 13:40
FRC #3045
Thanks for all the suggestions.
It appears (and we'll have to double check) that the PID does control to the target speed and direction. That is Set(1000) makes it go 1000 RPM in one direction; Set(-1000) at the start would go the opposite direction; but in this set of circumstances, Set(0) doesn't stop it.
What does work, which is a horrible hack, is to switch to Voltage mode, Set(0), then set back to PID mode.
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly "SWAT")
