Go to Post Gotta love it... FIRST's GDC...providing entertainment to loads of bored Bostonian FIRST'ers on a friday night. - Andy Grady [more]
Unread 07-03-2016, 22:47
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: Structural Integrity of Competition Defenses?
In Waterbury we started seeing problems with the pegboard s-hooks that we were told to use, due to the tight clearance of the drilled holes for the pins designated for that purpose, aka they wouldn't push in. We saw it mostly on the Rock wall, then more on the other defenses after they were switched into a spot vacated by the Rock wall. Those robots that didn't adjust their designs to accommodate the rock wall height were the ones that slammed up & over. Most others with Pneumatic tires flowed over. There was a lot of force generated to cause the damages. Except for the mounting design, I thought the defenses were built fairly well. By Sunday morning we had destroyed all the s-hooks & switched back to the pins, which now fit (loosely) into the holes. Now the rock wall started jumping up. We finally gaff-taped across the front/back of the defense to the floor mount & that worked. This is not a solution, just a band-aid.
The low goal curtain was damaged many time & we taped them back together. We got more curtains made up from the school sewing class with a slightly smoother material & they lasted longer.
I have a few suggestions to correct the problems with defenses lifting up, but there is not enough down time or personnel in between weekends to fix them. Obviously this is occurring throughout competitions & I hope they come up with a solution
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
