Go to Post I worship whoever cleans the robotics room. - John Gutmann [more]
Unread 08-03-2016, 00:32
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Dashboard Saving Values
Originally Posted by Bpk9p4 View Post
after some trial and error i did figure this out. I also found the file on the RoboRio where it is save /home/lvuser/natinst/LabVIEW Data/persistent.ini
Is there any way i can read this file using the dashboard?
Is there a reason you don't want to store the files locally on the same file system as the dashboard itself?
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
