Go to Post Limits are imposed by both man and nature. Understanding those limits and attempting to push past them is the basis of creativity. - Dave.Norton [more]
Unread 03-07-2016, 04:38 PM
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Can connect to the roboRIO by IP but not by hostname
We have run into this issue where one laptop (the programming laptop) is not able to connect to the roborio by hostname (roborio-5428-frc.local), but we can connect via IP (10.54.28.90). This problem only exists with this laptop, however, it is our programming laptop, and we are unable to upload code or ssh files into the rio by hostname. This also causes the driverstation to not be able to connect to the robot, even though it can connect to the radio. Using another laptop is not feasible right now. I hypothesize the issue occurs on the side of the laptop.
Hsifeulbhsifder
___________________
"Any given computer program is obsolete, any set of written rules is incomplete"
Unread 03-07-2016, 05:07 PM
Re: Can connect to the roboRIO by IP but not by hostname
The standard questions apply:
- What is the operating system on the troublesome PC?
- Are all firewalls off?
- All anti-virus off?
- Extra NIC's Disabled?
- Is the mDNS service running (NI mDNS Responder Service)?
- Is anything listed when you click on the arrow beside the team number on the Driver Station Setup tab?
If Windows 10 there are a couple of extra steps to turn things off.
Unread 03-07-2016, 05:24 PM
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
It is a windows 10 laptop. Firewalls and antivirus are off. Not sure if the extra NIC's are disabled. nimDNSResponder is running. Robot Radio is the only green light on the ds setup tab.
Hsifeulbhsifder
___________________
Unread 03-07-2016, 05:26 PM
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Is the laptop set for static ip or dhcp?
Unread 03-07-2016, 05:35 PM
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
It is set to DHCP.
Hsifeulbhsifder
___________________
Unread 03-07-2016, 06:30 PM
For Windows 10 there is an additional step to turning off the firewall.
MamaSpoldi reported this one:
- On the regular firewall page is a link to Advanced settings.
- The Advanced settings page will be divided into several sections, but at the bottom of the first section (Overview) will be another link to Windows firewall properties.
- Under that turn the first item from On to Off.
- Then reboot the Win 10 machine for it to take effect.
Unread 03-07-2016, 06:42 PM
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We had a almost 2 hours FTA visit at Waterford Thursday night. Not happy, could not get through inspection because our drivers station would not connect with robot, to power the pneumatic tests. Many, Many things were checked and tested, and after the roborio was reflashed and re firmwared and reloaded something clicked and it started working. Arron the FTA is excellent, and very knowledgeable, have worked with him in the past, and always a pleasure.
I have been posting our issues with this for months now, we were a beta test team. There is something still a miss, somewhere.
I can plug in last years dlink, and everything works, and quick.
The one thing I did learn this weekend, is the new system needs IPv6 enabled. We always turned that off in the past. Maybe it will help someone.
The sooner we get behind schedule, the more time we have to catch up.
Unread 03-07-2016, 06:44 PM
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
Did this, but to no avail. The issue still exists.
Hsifeulbhsifder
___________________
Unread 03-07-2016, 07:49 PM
Try Disabling/reEnabling the NIC you are using to connect the PC.
Unread 03-07-2016, 09:34 PM
We have one laptop where the Driver Station doesn't want to make an initial network connection to the robot until we physically reset the roboRIO. It's a minor hassle so far.
Unread 03-08-2016, 12:22 AM
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I know this is slightly off topic, but since someone mentioned windows 10....
Be very aware of windows 10 and all the helpful features microsoft has created. For instance our driver station laptop managed to download an update while in the competition venue and rebooted and installed it - without our giving permission. This wouldn't have been such a problem if we weren't trying to USE IT with the robot to, you know.... drive.
It also re-enabled the firewall during the update, causing us 20 minutes of "why can't we connect to the robot" afterwards.
Windows 10 has a fantastic feature where it doesn't even have to connect to the internet to download updates. As long as another windows machine has it on the network you are connected to it will utilize a peer to peer system to grab the update.
Unread 03-08-2016, 12:38 AM
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Can you ping the roborio by host name? Does it display the correct IP when you ping? You might try ipconfig /flushdns (from a prompt) to clear any cached names.
Has anyone by chance modified the hosts file by adding the host name to it?
We switched to static addresses this year, added its name to the hosts file and connected at our first district competition just fine. We set to roboRio to .2 and the driver station to .5 Note that the driver's station must have a mask of 255.0.0.0. Also, I believe we did turn off IPv6 on the DS. I haven't heard about needing it. Maybe Greg McKaskle could comment on that.
The other tip that keeps coming up is plugging the roborio into the connector on the radio closest to the power plug.
Brian
Brian K
Team 1225 Robotics Mentor
Unread 03-08-2016, 12:39 AM
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Try giving your RoboRio the IP address of: 10.54.28.2
Unread 03-08-2016, 07:14 AM
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
Was told the IPv6 has something to do with the Driver Station idiot lights on the communications tab. Even when it was working the Driver Station never reported the "correct" lights.
Enet Link
DS Radio
Robot Radio
Robot
FMS
In pit only Robot and Robot Radio would turn green, yet we could enable the robot.
Unread 03-08-2016, 08:10 AM
Enet Link
DS Radio
Robot Radio
Robot
FMS
That sounds normal.
In the Pit the lights that are green depend on how you tether.
You'll see different lights while on USB then on Ethernet directly to the roboRIO, or Ethernet through the robot radio.
