Go to Post Too bad MI isn't allowed to participate in FTC - Cory [more]
Unread 08-03-2016, 08:29
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Sally Port is a bumper destroyer
I've fount that our bumper corners are getting destroyed by the threaded ends of the screws that stick out on the back of the sally port. The worst part is that it is right in the middle of the bumper zone!
Can the GDC just turn the screws around? Robots contact the back of the door much more often than the front, so why don't we put the bumper friendly head of the screw on the side that touches bumpers?
Alternate solution: Drill a 7/8" dia hole where the nut and washer currently sit. This allows the nut and washer to sit on the back of the tube wall that is touching the polycarbonate panel (which I would say is generally a better way to attach things to tubes). The screw could be shorter, so it won't impale our beautiful bumpers!
Other solutions include: rivet nuts or Barrel nuts paired with nylon patch screws.
Otherwise, has anyone found fabrics that can deal with the screws?
Unread 08-03-2016, 09:00
protoserge's Avatar
protoserge protoserge is online now
AKA: Some call me... Tim?
Re: Sally Port is a bumper destroyer
Thanks for the feedback. Is it a wood screw or machine screw? I did not pay close attention to that and won't see the defenses until Friday.
If it is a machine screw, I will suggest adding acorn nuts.
Unread 08-03-2016, 09:28
It's a machine screw cutoff.
It can still protrude an eighth of an inch past the nut and may have a slightly ragged cutoff.
You can bring it to the attention of the field supervisor and ask for any sharp parts to be filed back.
Here's a photo of the Kickoff field before the bolt excess was cut back:
http://www.chiefdelphi.com/forums/at...7&d=1454516334
Unread 08-03-2016, 09:29
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Pretty sure it's just a large-ish machine screw... something like 3/8" diameter.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 08-03-2016, 09:36
Matt Ciprietti's Avatar
Matt Ciprietti Matt Ciprietti is offline
FRC #4039 (MakeShift Robotics)
Matt Ciprietti is a splendid one to beholdMatt Ciprietti is a splendid one to beholdMatt Ciprietti is a splendid one to beholdMatt Ciprietti is a splendid one to beholdMatt Ciprietti is a splendid one to beholdMatt Ciprietti is a splendid one to behold
My team actually asked a question related to this on the Q & A:
Q854
Q: The official field drawing of the Sally Port (GE-16035) shows 1/4 bolts attaching the door panel to the reinforcing structure. These bolts protrude 1/2" beyond the nut and are right in the middle of the robot bumper zone. While this may have been intended as an additional challenge, we are concerned many teams practicing with the flat-faced plywood SD depicted in the team version drawings will be ripped apart when driving through for the first time at competition. Will these bolts be shortened?
A: Thank you for pointing this out. The bolts used on the assemblies are 2.25 in. long and sit flush with the nut, and the drawing will be corrected as soon as possible.
So theoretically it should be cut off flush with the nut. If it is not, I'd suggest pointing it out to the field staff so that they can correct the issue.
Unread 08-03-2016, 11:28
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Perhaps if there is enough threads they can put on an acorn nut.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 08-03-2016, 11:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I didn't notice any bumpers getting torn at Lake Superior last weekend. I wonder if there was a difference in the fields between that event and yours.
2016: Lake Superior WFFA
Unread 08-03-2016, 11:53
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Here's a photo of one sally port at LSR that shows how the hardware is installed on that unit. I don't see any bolt sticking through the nut.
http://1drv.ms/1LOZgsF
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 08-03-2016, 13:11
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
An acorn nut is a good idea. Even with the bolt cut flush there is a potential to get caught, but with an acorn nut you could just slide through.
2017: Team 5940 (Silicon Valley Regional/San Francisco Regional)
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
