Go to Post Why climb up to the scaling rungs when you can move the entire field down to your robot's height? - marcusbernstein [more]
  #76   Spotlight this post!
Unread 08-03-2016, 02:32
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: 1678 Two Ball Auto
Originally Posted by Valkonn View Post
Jesus christ.... please have mercy on the central valley....
I kinda think that 254, 1671 and 973 won't be too intimidated...
  #77   Spotlight this post!
Unread 08-03-2016, 08:19
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Originally Posted by Chak View Post
Now imagine if you had two robots like this on one alliance! 60 point auto, not even counting the third robot, so potentially 70 or 80 point. In addition, the 4 balls scored in auto and the minimum 3 balls starting in the castle means that the opposing HP is forced to release at least 1 ball at the beginning of tele-op. At that moment, all opposing robots will be on the other end of the field, allowing this ridiculously overpowered alliance to grab the boulders off the secret passage without interference. This alliance would have a HUGE lead in points and cycle time!
Maybe I will to see this at IRI or on the Einstein field. One can hope...
To make this possible, one of the autonomous routines must be performed on a non-low bar defense. 1678, your move.
Pretty sure low bar is a necessity to pull it off (talk about auto traffic jam) ..doubt two robots pull that move off consitently but who knows. I think the single boulder possession rule make this nearly impossible.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
  #78   Spotlight this post!
Unread 08-03-2016, 09:03
axiomofdarkness's Avatar
axiomofdarkness axiomofdarkness is offline
FRC #1403 (Cougar Robotics)
axiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura about
It seems possible (though extremely hard) to do it with any other defense, except maybe the ramparts. I doubt it will happen before Einstein, if at all, though.
  #79   Spotlight this post!
Unread 08-03-2016, 09:39
Only thing that cancels ONE successful 2 ball auto (20 besides the cross) are 2 scaling bots (20 extra) so if 1678 pulls this off of the other alliances better find some scalers against them or 1678 better snatch up some scalers as captain..just sayin'
I think 1678 just made scaling bots top of peoples pick lists to defeat that alliance
20 points per match is 4 HG or 4 2x crosses or breach/capture...its huge
3 scalers are 1 HG better than 1 2-ball auto
Most everyone can cross in eliminations.
  #80   Spotlight this post!
Unread 08-03-2016, 10:09
Chris is me's Avatar
AKA: Pinecone
You (generally) want to maximize non-excludable points per robot per alliance in any case - these robots are no more or less valuable than they were before. You always wanted the points. I'm not picking a hanger specifically over an otherwise higher scoring shooter just because of 1678's auton (though this is admittedly a contrived situation).
  #81   Spotlight this post!
Unread 08-03-2016, 11:03
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
However the 2 ball auto also lowers the tower by 2 points.
Plus whatever your alliance members put up in auto.
Which will make it easier in tele-op to achieve a capture.
Scaling might offset the two ball in terms of points, but a two ball auto still is the stronger strategy IMHO.
Good enough is the enemy of anything great!
team 1671
  #82   Spotlight this post!
Unread 08-03-2016, 11:40
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Two ball autos can be pretty easily blocked though, while scales can not.
  #83   Spotlight this post!
Unread 08-03-2016, 11:46
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
Founder and CEO, DeadMemes Studios
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Explain? Seeing as you can't cross the midline, it is pretty hard to stop a two ball auto. The only way you could do it is a canburglar-esque race to the center ball, but seeing as they immediately intake the midline ball without moving, it seems pretty unlikely that you will be blocked.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
  #84   Spotlight this post!
Unread 08-03-2016, 11:47
AlexanderTheOK AlexanderTheOK is offline
Guy
AlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really niceAlexanderTheOK is just really nice
Well for one if you attempted to block an auton at all you would be on the wrong side of the field, which is illegal.
  #85   Spotlight this post!
Unread 08-03-2016, 11:58
Just start without a ball and have your intake ready to grab the ball as soon as the match starts. 1678 has to drop their ball first, so it would be relatively straightforward to beat them to the center ball.
There are more complicated 2-ball autos that could avoid being blocked, but considering we went through week 1 without any 2-balls at all, we probably won't see hardly any two ball routines more advanced than 1678's.
  #86   Spotlight this post!
Unread 08-03-2016, 12:02
Thanks great idea..almost like can wars fastest intake wins.... ours is really fast (Fastest at SD)
  #87   Spotlight this post!
Unread 08-03-2016, 12:11
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
It still requires a specialized auto mode, where you're lined up against the secret passage rather than a defense. So either your entire auto mode is preventing a two ball auto (the 1-ball will still work), or you're coming up with a much more complicated (read: more likely to fail) auto mode.
Yes, you can TECHNICALLY defend a 2-ball auto, but I don't believe the tradeoffs are worth it.
  #88   Spotlight this post!
Unread 08-03-2016, 12:18
AdamHeard's Avatar
Lead Mentor
Who says you can't still cross after doing this?
We plan to have such an automode ready for champs.
  #89   Spotlight this post!
Unread 08-03-2016, 12:21
ASmith1675's Avatar
AKA: Adam Smith
Nothing says you can't. It's just more complicated than it initially sounds if you're not thinking about field configuration.
  #90   Spotlight this post!
Unread 08-03-2016, 12:24
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Looks like we'll have to add our surgical tubing powered, 1" diameter carbon fiber arms to grab the ball at 120mph
I'm getting flashbacks to 2015, the horror!
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
