Go to Post GP is best shown and lived and not talked about. - Steve W [more]
Unread 08-03-2016, 09:41
Hsifeulbhsifder Hsifeulbhsifder is offline
Programmer
AKA: Zaeem Mohamed
FRC #5428 (Breaking Bots)
Rookie Year: 2015
Hsifeulbhsifder is on a distinguished road
Re: Can connect to the roboRIO by IP but not by hostname
Originally Posted by SuperBK View Post
Can you ping the roborio by host name? Does it display the correct IP when you ping? You might try ipconfig /flushdns (from a prompt) to clear any cached names.
Has anyone by chance modified the hosts file by adding the host name to it?
We switched to static addresses this year, added its name to the hosts file and connected at our first district competition just fine. We set to roboRio to .2 and the driver station to .5 Note that the driver's station must have a mask of 255.0.0.0. Also, I believe we did turn off IPv6 on the DS. I haven't heard about needing it. Maybe Greg McKaskle could comment on that.
The other tip that keeps coming up is plugging the roborio into the connector on the radio closest to the power plug.
Brian
We are not able to ping by hostname, although we can ping by IP.
Hsifeulbhsifder
___________________
"Any given computer program is obsolete, any set of written rules is incomplete"
Unread 08-03-2016, 09:53
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
Originally Posted by rich2202 View Post
Try giving your RoboRio the IP address of: 10.54.28.2
How exactly do you do that?
Hsifeulbhsifder
___________________
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
But what happens when you ping - do you get no response or it unable to resolve the host name? If it does resolve the host name to an IP address is it correct?
Brian K
Team 1225 Robotics Mentor
Unread 08-03-2016, 10:06
Originally Posted by tr6scott View Post
Was told the IPv6 has something to do with the Driver Station idiot lights on the communications tab. Even when it was working the Driver Station never reported the "correct" lights.
Enet Link
DS Radio
Robot Radio
Robot
FMS
In pit only Robot and Robot Radio would turn green, yet we could enable the robot.
  • Enet Link should light when there is a physical Ethernet connection active. It will be off in the pit when tethered with USB.
  • DS Radio should light only when you're doing something fancy with a wireless access point connected to the Driver Station computer and with the Robot Radio configured as a bridge. It will be off in the pit when tethered with USB.
  • Robot Radio should light when you're connected to the robot via wired or wireless Ethernet. It will be off in the pit when tethered with USB.
  • Robot should light any time you have a network connection to a properly configured roboRIO.
  • FMS should light only when you are plugged in on the competition field. It will be off in the pit when tethered with USB.
I'm surprised Robot Radio was lit. Are you not using the USB connection to tether to your robot in the pit?
Unread 08-03-2016, 10:09
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
It doesn't resolve the hostname.
Hsifeulbhsifder
___________________
Unread 08-03-2016, 11:00
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
So it turns out I can ping roborio-5428-frc.lan, which gives me 10.54.28.90. But I can't ping the local, even though this is done over wireless connection.
Hsifeulbhsifder
___________________
Unread 08-03-2016, 11:27
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
We also have a raspberry pi attached to the radio, which has the static IP 10.54.28.13. And I can't ping or connect to it by its hostname either, although I can connect via IP. The rPi is running an avahi-daemon, so I can connect to it from other laptops by hostname.
Interestingly enough, I can ssh into the raspberry pi via IP and once inside the pi, I can ping and connect to the rio via hostname.
Hsifeulbhsifder
___________________
Unread 08-03-2016, 14:04
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Use the RoboRio USB Interface (the square plug on the RoboRio connected to the rectangular port on your Driver Station).
You need Silverlight installed on the Driver Station.
Navigate in the Browser to: 172.22.11.2
Select Network Configuration Options on the left side (4th icon that looks like an ethernet cable).
Configure IPV4 address
https://wpilib.screenstepslive.com/s...anual-id=24166
This will help you get to the RoboRio through the USB interface
https://wpilib.screenstepslive.com/s...g-your-roborio
Unread 08-03-2016, 14:43
Greg McKaskle can't actually comment on it yet. He attends his first event in a few days, and hasn't actually seen these issues in order to be able to debug them. And of course seeing isn't the same as having time to debug.
He does have a Win10 Lenovo that frequently doesn't show link when connected to the roboRIO. Disable/Enable on the interface fixes this and is somewhat faster than the roboRIO reboot. The other computers he tested with don't have this issue. He thinks this is related to power management features and is talking to folks about it.
And he isn't used to speaking about himself in the third person.
The third person
Unread 08-03-2016, 15:59
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
New discovery: If I connect via ethernet, then I can ping and connect to the rio via hostname and IP, and can connect successfully from the driver station. When I pull out the ethernet cable while connected, and switch to wireless, the driverstation remains connected, but I lose the ability to ping or ssh via hostname.
Hsifeulbhsifder
___________________
Unread 09-03-2016, 16:33
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Our symptom is that the Enet Link is never lit, even when Ethernet tethered on practice field with the bot enabled.
Rest sound right.
I have never seen DS Radio lit either when tethered.
I did see FMS work on the field.
The sooner we get behind schedule, the more time we have to catch up.
Last edited by tr6scott : 09-03-2016 at 16:35. Reason: added Ethernet as to not confuse with USB tethered.
Unread 09-03-2016, 17:14
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
I had the same issue.
Ended up just plugging in a USB printer cable and connecting to the roboRIO (The ip when connected via usb is always 172.22.11.2).
Then I changed it to a static ip and changed it to 10.36.47.2
To connect to the robot, change your IPV4 address to a static one. I used 10.36.47.5
Unread 09-03-2016, 22:41
SuperBK's Avatar
AKA: BrianK
Third Person: Tell Greg to have fun. I had a blast at the NC Guilford County district last weekend.
Hsifeulbhsifder: Sounds like there are some issues with mDNS and Windows 10. I would just switch to static and move on.
All: Here is an interesting article that mentions mDNS support in Windows 10. I know, the FRC software installs its own mNDS service, but maybe there is something build into Windows 10 that is conflicting with it.
Check out this line:
Windows will special‐case domains ending in the .local TLD...
and
The end result of this inconsistent support is that you may or may not be able to reach other machines from programs, games, and web browsers by typing in their mDNS address (for example MacBook.local).
https://www.slightfuture.com/technot...ows-mdns-dnssd
Brian K
Unread 10-03-2016, 22:26
Programmer
AKA: Zaeem Mohamed
Rookie Year: 2015
We switched to static, but we ran into an issue at Greater Toronto East Regional where we were not able to connect to our rio after the configuring the radio. This involved switching from Static to DHCP, which made it so our rio did not have a valid IP at all, so to get an IP we would need to connect it to a DNS server, the only one being the field. Which asks another question: Do teams that are using co-processors connected to the radio, have to also undergo this process if they were static before?
Thank you.
Hsifeulbhsifder
___________________
Unread 10-03-2016, 23:00
sanelss sanelss is offline
FRC #1658
sanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to beholdsanelss is a splendid one to behold
Thank you.
Not sure if it's related but we're having major issues!!! spent ALL day today trying to fix it and we still don't have a solution.... we currently do not have working vision simply because our vision tablet can't communicate properly and it's all because of the real field setup.... works fine at home and prac field...this issue may very well cost us the one and only regional we do a year.... I really don't know what else can be done. here is the current post on it:
http://www.chiefdelphi.com/forums/sh...d.php?t=145546
