Go to Post It's in the RUMOR MILL section, hence it is a RUMOR. Personally I find it entertaining to see what gets started in this particular forum section and have people go off the deep end. - Gary Dillard [more]
Unread 08-03-2016, 10:07
FRC API
I have an FRC API Python script that I used (successfully) one year ago this month to retrieve some data.
Now when I run the script I get this error:
urllib2.URLError: <urlopen error [Errno 10061] No connection could be made because the target machine actively refused it>
So I was wondering if there is an effective process in place for getting assistance with FRC API errors. A help desk if you will. Or a guru here on CD.
Unread 08-03-2016, 10:14
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
Have you changed the URL to reflect FIRST's URL change from usfirst.org to firstinspires.org?
Unread 08-03-2016, 11:30
Re: FRC API
Yeah, that was it. Reps to you
Unread 08-03-2016, 11:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: FRC API
Ether - I use the API to calculate the official rankings for the MN State Championship (at least, last year and this year). While I have it all set up in Java, if be happy to help if you run into any more issues. I know the domain change hit me earlier this year as well!
Also, there is the official teamforge page for the API - I don't know how often people check the discussion board there, but it could be another place to look for help.
2016: Lake Superior WFFA
Unread 08-03-2016, 11:43
Re: FRC API
Thanks Jon I will keep that in mind.
Unread 08-03-2016, 11:50
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
Re: FRC API
According to their TeamForge page:
Tokens are removed if the account is inactive for over 6 months (0 requests), or has been banned for one month without contacting us. If your token disappears, just send us a message and we'll help you out.
Unread 08-03-2016, 11:53
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: FRC API
Here is a like to the apiary page that contains the full api docs (there were some updates for 2016):
http://docs.frcevents2.apiary.io/#
Unread 08-03-2016, 12:21
Re: FRC API
Thanks for pointing that out.
That's a very ill-conceived policy for something annual like FRC. It should be at least a year, if not 18 months.
