Go to Post I highly doubt the game has anything to do with water... - rotolomi [more]
  #91   Spotlight this post!
Unread 08-03-2016, 12:29
AdamHeard's Avatar
Lead Mentor
Re: 1678 Two Ball Auto
Originally Posted by Smitty1707 View Post
Nothing says you can't. It's just more complicated than it initially sounds if you're not thinking about field configuration.
I am thinking about the field configuration, and it's not that complicated. Certainly easier than a 2 ball auto.
  #92   Spotlight this post!
Unread 08-03-2016, 12:40
ASmith1675's Avatar
ASmith1675 ASmith1675 is offline
Mechanical/Electrical/Scouting
AKA: Adam Smith
ASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to beholdASmith1675 is a splendid one to behold
Didn't mean to imply you weren't or that it can't be done. It certainly can (and likely will).
The point I was trying to get across (poorly, perhaps) was that if you're blocking a two ball with your auto mode, but this prevents you from doing anything positive for your own alliance, then its not worth it. Having an auto mode that "steals" the center ball then still does something useful afterwards will likely be one of the more challenging routines.
  #93   Spotlight this post!
Unread 08-03-2016, 13:13
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The secret benefit to a 2-ball auto: if your partners also score their boulders in auto, your opponents are forced to stuff a ball into the secret passage right away. At Worlds, this will be the game changer. A tower won't stand a chance when it's only 3 damage away from a capture in the opening seconds of teleop.
GitHub
  #94   Spotlight this post!
Unread 08-03-2016, 13:36
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by axiomofdarkness View Post
It seems possible (though extremely hard) to do it with any other defense, except maybe the ramparts. I doubt it will happen before Einstein, if at all, though.
Second best defense for 2-ball auto is the portcullis if you have a mechanism that lets you reverse through it. Or since you need a pickup on your back side to do this, probably a mechanism on your front side as well as on the pickup. After that your percentages probably drop by a lot since you're likely being randomized by the defense or the landing afterwards.
Last edited by Kevin Sevcik : 08-03-2016 at 14:25. Reason: Changing edit to a second post....
  #95   Spotlight this post!
Unread 08-03-2016, 14:21
Richard.Varone's Avatar
Richard.Varone Richard.Varone is offline
AKA: Rich Jr.
FRC #0271 (Mechanical Marauders)
Richard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really niceRichard.Varone is just really nice
Send a message via MSN to Richard.Varone
Oooooo I like the way this sounds, not as a defense against the 2 ball auto but as another position a 2 ball auto could take place in, I'm glad that not only did we decide to put a herder on the front and back of the bot, but both herders are capable of opening the portcullis. Time to push the programmers even harder!
2016 FLR (Excellence in Engineering)
2015 NY (Regional Finalists) & LI (Quality Award)
2014 NY (Regional Finalists, Quality Award) & LI (Regional Finalists, Quality Award)
2011 LI (Regional Finalists, Innovation in Control)
2010 LI (Regional Champion, Engineering Excellence, Coopertition Award) & NY (Regional Finalist)
2009 LI (Innovation in Control) & NY (Creativity Award)
2008 LI (GM Industrial Design) & NY (Innovation in Control)
2007 LI (Delphi "Driving Tomorrow's Technology")
2006 LI (Regional Champion)
2005 LI (Regional Finalist)
2004 SC (Regional Finalist)
2003 LI (GM Industrial Design)
2002 CMP (Division Finalist - Newton)
2001 NY (Imagery)
  #96   Spotlight this post!
Unread 08-03-2016, 14:25
OTOH, any defense that's not the low bar has increased difficulty because you don't have a wall to stop your dropped ball. That cardboard field border looks pretty integral to 1678's auto routine. Without it, you have to worry a lot more about an inconsistent ball running away from you.
Also, also, an alternate, option for interfering with this style of 2-ball auto: instead of stealing the first ball (maybe you're not fast enough), bump the second ball with your ball. This assumes you have nothing better to do with your ball, and that you can outfeed fast enough to get both balls clear of the infeed path. Still, second picks often have nothing better to do with their ball, and it'd be an easy routine to write. Oh. Bonus points if you steal the first ball, and then shoot it at the dropped ball to turn a 2-ball auto into a 0-ball auto.
  #97   Spotlight this post!
Unread 08-03-2016, 16:08
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
FYI, We will be showing off the unedited version of the video (i.e. no grinder) on our show on Wednesday. Thank you so much to the students and mentors on 1678!
If you want to catch it live, check it out Wednesday at 9 PM ET at twitch.tv/FRCGamesense or youtube.com/FRCGameSense
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
  #98   Spotlight this post!
Unread 08-03-2016, 16:10
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
This is really the biggest crux around auto this year. The more you score in auto (where you don't have to worry about defense, just run the same routine you've run all season), the less you have to score in teleop. Every ball your alliance scores in auto means just that much more time for every cycle, and gives you leeway should you run into a little bit of shot inconsistency or heavy defense.
2012 - 2015 : 624 CRyptonite
Team Website
  #99   Spotlight this post!
Unread 08-03-2016, 16:33
Doiteain's Avatar
Doiteain Doiteain is offline
That tall guy over there
AKA: Cuyler
FRC #5026 (Iron Panthers)
Doiteain is infamous around these partsDoiteain is infamous around these parts
Originally Posted by RoboChair View Post
I will bet a 2 inch Turner's Cube that we won't see a successful 3 ball auto all season in a match.
I'll remember that.
  #100   Spotlight this post!
Unread 08-03-2016, 17:05
RoboChair's Avatar
AKA: Devin Castellucci
Originally Posted by Roboshant View Post
Will you guys be releasing an unedited version of this video after your first competition?
Yes, you will be able to see it on GameSense this Wednesday.
Link here: http://www.chiefdelphi.com/forums/sh...40&postcount=2
12 Years and counting! Over a third of my life has been spent with FRC.
  #101   Spotlight this post!
Unread 08-03-2016, 21:25
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Definitely thought of this but be careful about the definition of launching.
D. “launching” (shooting BOULDERS into the air, kicking across the
floor, or throwing in a forceful way)
G39 ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s
TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet.
Violation: TECH FOUL per BOULDER
  #102   Spotlight this post!
Unread 08-03-2016, 21:36
That's one of those frustratingly vague rules the gdc put out this year. If we were doing this, we'd be reversing our intake to do this. We'd be rolling a ball, but I have to assume rolling a ball fast enough would eventually be considered launching. It's just that you don't know how fast that is.
  #103   Spotlight this post!
Unread 15-03-2016, 23:15
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I only got a chance to watch some of the elimination matches, but was this successful or ran last weekend?
  #104   Spotlight this post!
Anteprefix's Avatar
Anteprefix Anteprefix is offline
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
It was not attempted at CVR.
The scouting! It never ends!
  #105   Spotlight this post!
Unread 15-03-2016, 23:21
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
They said up front to me in the pits no two-ball auto in CVR as the video was in a controlled setting on marks setting...does not matter 1 ball auto and the 100% scale and literally unblock-able shots was enough..them and 254 were amazing to behold they obviously set the high bar at 210.
So was the rookie team Uni-Rex when not broken , the combo of their swerve with 75MPH High goal laser with deadly accuracy was freaking amazing. So was 973 with their flashlight aim perfection HG shots. Also 1323, 701 and 1671 too. And many others.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
