Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Unread 29-01-2016, 22:49
Manusha4Lyfe Manusha4Lyfe is offline
FRC #5124
Manusha4Lyfe is an unknown quantity at this point
Wink GRIP Overlaying Contours Onto Images
I was wondering if it is possible to overlay contours detected in GRIP back over the original image feed . Thanks for your replies
Unread 30-01-2016, 13:59
dszlucha dszlucha is offline
FRC #1518 (Raider Robotics)
Rookie Year: 2016
dszlucha is an unknown quantity at this point
Re: GRIP Overlaying Contours Onto Images
Using the vision algorithm from the "Using GRIP for the 2016 game" tutorial I was able to do this by adding a Mask operator and hooking the output of the original or resized image to the mask input and the output of the HVL Threshold to the mask input of the mask operator. For whatever reason I couldn't set the output of Find or Filter Contours to the mask input of the Mask operator.
David
Unread 31-01-2016, 17:40
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Assuming you're trying to look at contours on the driver station while GRIP is deployed, I'm working on a SmartDashboard plugin for GRIP that should do something similar to this.
https://github.com/WPIRoboticsProjec...SmartDashboard
It gets feature data from NetworkTables and images from GRIP's "Publish Video" operation. Unlike SmartDashboard's built-in USB Camera viewer, it should work if GRIP is running on either the roboRIO or a coprocessor, since there's an option to set the address.
It doesn't have support for rendering contours yet, but it's on the way.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 08-03-2016, 20:02
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Thomas,
What is the status on this? We'd love to give it a try.
Thanks,
Martin Haeberli
(de-)mentor, FRC 3045 Gear Gremlins (formerly SWAT)
Unread 08-03-2016, 20:04
FRC #0237
Originally Posted by mhaeberli View Post
Thomas,
Thanks,
Martin Haeberli
It now supports rendering contours.
https://github.com/WPIRoboticsProjec...board/releases
Unread 08-03-2016, 21:02
FRC #3045
thx!
Unread 08-03-2016, 21:10
FRC #3045
One more question - where on my Mac would I find SmartDashboard/extensions ... ?
Unread 08-03-2016, 21:38
FRC #3045
Ok, found that - ~/SmartDashboard/extensions/ - of course!
Unread 08-03-2016, 23:42
FRC #3045
Next question - does it / can it work with SFX - SFX 2014?
Unread 10-03-2016, 13:24
FRC #0237
Probably not, unless someone writes an SFX port of the extension
Unread 13-03-2016, 00:21
FRC #3045
Any suggestions on debugging wuth the current SmartDashboard extension if overlays aren't showing up?
Also, is there a way to overlay, say a number (e.g., size) from GRIP, or, more generally, from NetworkTables, via GRIP's video out? That would be _very_ cool!
Thanks,
Martin Haeberli
Unread 14-03-2016, 14:39
robert1356 robert1356 is offline
AKA: Robert Palmer
FRC #3824 (RoHAWKtics)
robert1356 is an unknown quantity at this point
Simplest way is to add a call into the disabledPeriodic(), autonomousPeriodic() and teleopPeriodic() that calls a method for updating your GRIP information. Inside this method, you just read the parameters from the GRIP table and put them on the smart dashboard. Not as nice as an overlay, but works quite well.
I also have a boolean configured as a box (so it shows red/green) for "Is Image processing running" I do this by looking at the frame rate. If it's zero, it's not running, if it's non-zero, it is running. I always set the value to zero at the beginning of the robot code - sometimes values get stuck in the network tables - this makes sure that the tables have a zero if the image processing isn't running.
Unread 14-03-2016, 20:55
FRC #3045
nice!
