Re: Limit Switches
I think your problem is the values going to the bottom range input of the In Range and Coerce function. The select function controlled by the TuskBottomStop switch will give it either 0 or 1, which will keep the motor from ever going down, and will force the motor to go up when the switch is pressed.
Try changing the 1 to a -1 instead. |
