Go to Post Sure, whining is easier than working, but what's more rewarding? - PayneTrain [more]
Unread 09-03-2016, 02:12
josephno1's Avatar
josephno1 josephno1 is offline
FRC #3647
Rookie Year: 2015
josephno1 is an unknown quantity at this point
Re: Usb camera
Here is a grip file to help you get started.
It does a half decent job of detecting targets. You might want to play around with contour areas and rgb stuff.
I also uploaded some sample picture that you might want to play around with it.
Use network tables to use it in the java code
Unread 28-03-2016, 15:44
ARaine ARaine is offline
FRC #2834
ARaine is an unknown quantity at this point
Re: Usb camera
I found that using the vision to directly control a motor was too slow. By using a gyro, I calculated (roughly) the angle needed to rotate so that the center of the target was on the center of the camera's vision.
The calculation was:
arctan([Distance of center target to center vision] / [Constant])
The constant is just a value that I found through experimentation (around 300, may be different for you). This method only works if you have a gyroscope because I then took that calculated angle and plugged it into a PID loop to rotate the robot based on a gyro reading.
I had some success with this in autonomous by performing this operation twice.
