Go to Post I think we can all remember, no matter our age, that we are always responsible for our own actions and reactions. - JaneYoung [more]
Unread 09-03-2016, 00:44
ktcottrell ktcottrell is offline
FRC #0687
ktcottrell is an unknown quantity at this point
Microsoft Camera Mounting
My team has been having trouble mounting the Microsoft camera onto our robot. Does any team have a solution to this? I have a 3D printer and would be able to print a piece, which is what we did for the axis camera but we want to use the Microsoft camera instead and i havent been able to find a cad of the camera or a mount another team has used.
Thank you
Unread 09-03-2016, 02:21
Re: Microsoft Camera Mounting
Ours is zip-tied to a piece of Lexan with a rectangular hole that matches the area around the lens. The ties go in an X shape behind the camera body, through four holes in the Lexan, and vertically in front of it on either side of the lens.
The Lexan is actually a pneumatically actuated bracket that can pivot up and down, but it could just as easily have been bolted or riveted in a fixed position.
Unread 09-03-2016, 07:33
ty.sayman ty.sayman is offline
FRC #5190 (Green Hope Falcons)
ty.sayman is an unknown quantity at this point
We did the same thing with ours. Then, had another student go wild and (carefully) take the arm off the camera and then mount it and a ring light right to a piece of windowed Lexan with double-sided tape from the KOP.
Oh, and our first one had some duct tape on the back for engineering completeness, excellence, or inspiration...I forgot which.
Unread 09-03-2016, 08:00
weaversam8 weaversam8 is offline
Team Captain
AKA: Sam Weaver
FRC #4534 (Wired Wizards)
weaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to beholdweaversam8 is a splendid one to behold
We extended the flexible mounting piece and clamped it between two parts of the robot that have a lot of weight— we then used foam to make sure the lens was immovable.
ORB Haow!
Unread 09-03-2016, 08:13
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
We drilled two holes in the base and bolted it onto the frame to hold it. Then we bent it into "square" format, stuck a piece of grippy wood inside the square, and zip-tied it down.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 09-03-2016, 08:16
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
We use the attached 3D printed mount, which includes space for two concentric LED rings. In this version, the clips that hold the camera in require some sanding to allow the camera to be pushed in, or they could be made smaller in the model.
The mount is designed to be mounted behind a piece of lexan using the spacer (the other model in the zip).
There are also a couple of holes that are designed to allow zip ties to hold the camera in more securely.
Unread 09-03-2016, 10:18
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is online now
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Here's our mount. You push the bendy bit through and bend it on the other side. You can ziptie it as well. The mount also has space for the standard size LED ring.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 09-03-2016, 12:47
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Here's ours from back just epoxy glued the ring on front and took off bendy thing..it works and is solid. Old school mount.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 09-03-2016, 16:53
Bob Potts's Avatar
Bob Potts Bob Potts is offline
Consultant
FRC #4130 (The Blue Devils)
Bob Potts is an unknown quantity at this point
217-4178 (VersaFrame 1" Wide VersaPlanetary Parallel Mount)
These work pretty good too.
Unread 17-03-2016, 16:08
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
Fits very nicely inside of a section pf 2x2 box aluminium tubing. If you recess it slightly you have an almost indestructible mount / protective frame that you can then drill and tap or even ziptie to whatever.
Duct tape or zip tie the camera in the tubing for temporary mounting. Pot it with silicon for a shock damping semi-permanent mount.
Unread 17-03-2016, 16:11
Mechvet Mechvet is offline
Certified Public Menace
FRC #0114
Mechvet is a jewel in the roughMechvet is a jewel in the roughMechvet is a jewel in the rough
Here's our solution.
We found that current pan/tilt mounts took up too much space, so we made on that's smaller.
If you don't need pan or tilt, just print the camera holder and go from there. Or, if you'd like I can send you some CAD files for either part so you can modify/integrate as you see fit.
Unread 17-03-2016, 16:30
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
We removed the circuit board from the housing and 3d printed a low profile case. We had size limitations that pushed the students in that direction. If anyone wants the files to print, just let me know.
Brian
Unread 17-03-2016, 16:31
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
My team currently cut into some aluminum, I'm not sure the size, but made a hole into it so the camera is within the frame but can not fall out, and a plate that holds the camera into the back. It's hard to explain, I may be able to find a picture.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
