#13
Re: Team Update 15 (2016)
My thoughts of 4mm thick heavy plastic strips getting raked over the inside of bot, swatting the cameras twice a cycle, are getting worse or worse. If they are stiff enough, they'll form a robot check valve out of the low bar. Once you are about halfway through and just one strip falls in the bot, you probably can't back out for any reason.
