Go to Post I'm throwing the Unnecessary Sarcasm Flag here. - Joe Johnson [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 09-03-2016, 15:01
TCMJ1816's Avatar
TCMJ1816 TCMJ1816 is offline
Peter
AKA: Peter Hartnett
FRC #1816 ("The Green Machine" (Alumnus))
TCMJ1816 will become famous soon enough
Are 8 play regional reasonable?
While watching Top 25 last night they brought up the point that many regional competition only offer 8 qualification plays per team. In Minnesota we have 208 teams, and a vast majority of those teams only get one event a year.
I see 2 major issues with this:
-This make the $5000 it costs to register for events pretty crazy, $625 a match isn't appealing for many of the low budget teams around FIRST.
-This also leaves the teams that do qualify for champs hugely unprepared. Most MN teams at champs will have ~20 plays, versus district teams that will have 40+ plays. EDIT: Many teams come into champs with 80+ plays
There definitely isn't a great solution to this problem, other than going to districts, but that has been addressed in the past.
To get what you've never gotten, you must do what you've never done.
Unread 09-03-2016, 15:06
JohnSchneider's Avatar
JohnSchneider JohnSchneider is online now
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Are 8 play regional reasonable?
You could hold local scrimmages and practice all the way through the season.
But that would also require an entire second robot because "lol 6 weeks build".
Unread 09-03-2016, 15:07
maxnz's Avatar
maxnz maxnz is offline
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
I have a feeling that Minnesota or the upper Midwest (MN, WI, IA, ND and/or SD) will become the next district within the next few years. We already have four regionals, two in Duluth and two in the twin cities, plus a regional in Iowa.
Unread 09-03-2016, 15:10
TCMJ1816's Avatar
Peter
AKA: Peter Hartnett
This is becoming much more common, I know of at least 10 practice bots and 5+ practice fields all around the state. I can't imagine more than about 25 teams make second robots.
Unread 09-03-2016, 15:13
FRCTeam3293 FRCTeam3293 is offline
FRC #3293
FRCTeam3293 is an unknown quantity at this point
Amen Brother.
Unread 09-03-2016, 15:22
Data Nerd
FRC #0079
40... Thats almost the min that most district teams will have. We aren't normal so coming into CMP with 100+ matches isn't common, but coming in with 60-80 is fairly easy to do in districts.
So no, it's a disadvantage to the teams coming into teams with only 14 matches (8 QM + 6 EM). It's also a stupid high cost per match.
It's also a big issue because the ranking algorithm gets more accurate the longer it can run.
In short, absolutely not.
Unread 09-03-2016, 15:23
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Are most regionals only at 8 qualification matches. From what I understand most are at somewhere between 10-11.
Unread 09-03-2016, 15:36
TCMJ1816's Avatar
Peter
AKA: Peter Hartnett
I am under the understanding that all 4 MN events will only be 8 matches per team. Looking at other regionals I think you are correct, the 2 I checked had 9 matches per team.
Unread 09-03-2016, 15:56
Ginger Power's Avatar
Ginger Power Ginger Power is online now
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
I'd love to go to districts which would solve this problem. The issue is with key volunteers. Minnesota would have to do 12 events which is a lot of field setup/teardowns, and a lot more work for our key volunteers. I know our Volunteer Coordinator is crazy busy as is with 4 (5 if you count Iowa) events. We do have a great crop of college level volunteers on the way. When some of us start transferring into key volunteer positions, we'll be ready for the move to districts. Which will solve the problems.
A band-aid solution will be adding another regional which could happen within a year or two. This will allow more teams to do 2 events. The cost will still be crazy, but at least the opportunity will be there.
All we can do to help is recruit more volunteers, and get them trained into key volunteer positions!
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns 2015/2016 Project Lead: Reveal Paper
Unread 09-03-2016, 16:08
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
It's all dependent on the number of teams registered.
Northern Lights at 60 teams could have snuck in 9 per team, but Lake Superior at 63 teams could not. We have the same problem in Minneapolis, so I would expect both events to stick to 8 again.
I also take issue with dividing the $5,000 up by the number of matches and valuing the competition on a per-match basis.
First, the $5,000 is your ticket into both your first event and the season as a whole. How much is the rest of the FRC season worth to you? Is build season worth $0? The KOP? Of course this "value" will be the same between both, but just saying that a regional costs $625/match doesn't take that into account.
A regional also comes with a lot of other differences- bigger venue, more teams, more money spent on the A/V setup, etc. How much are those things worth to you and your team?
Now if you really do just want to compare on a cost-per-match basis, I won't argue that districts are a better "deal." And yes, district teams do come into championships with more plays as well. I just don't personally believe it is quite that simple.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 09-03-2016, 16:10
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The number of qualification matches is highly dependent on the number of teams at an event (fewer teams means more matches per team) and the cycle time between matches. With the defenses this year, cycle time is up compared to some other years. Last year MN events had 9 matches per team, and in 2014 (with practically no items for field reset to have to place) we got 10.
I know, I want more plays for my team... But I also know that there are challenges associated with switching to districts. Everyone involved is determined to provide the best experience for teams each year, and from what I've heard and seen, MN has some of the best events around . After all, who else could get an Air Force Flight Simulator ride running for everyone to enjoy at their event like we had in Duluth?
And I want to give a big shout out to the crew from Bison Robotics at NDSU... 29 (i think) of them made the trek all the way across the state to volunteer in Duluth, and a similar number are signed up for the Minneapolis events in week 6 as well. Wow!
2016: Lake Superior WFFA
Unread 09-03-2016, 16:13
pHolmgren's Avatar
pHolmgren pHolmgren is offline
AGM
AKA: Preston Holmgren
FRC #2557 (SOTABots)
pHolmgren has a spectacular aura aboutpHolmgren has a spectacular aura about
This is why the district system is great. It world fantastic here in PNW.
Preston Holmgren
FRC 2557 SOTAbots
Unread 09-03-2016, 16:29
Data Nerd
FRC #0079
So, how much of my registration fee is a flight simulator ride worth? If we didn't have it, could we have more matches?
I'm being snarky of course. But my point is, at it's core this is a ROBOTICS COMPETITION. It's cool to have other things but at the end of the day $625 a match is a tough pill to swallow.
And, look, I get you and I value different things in events but I would like to think that we could agree on the fact that 8 matches is unacceptable and I'd rather go to an event that gives me more matches than the self proclaimed "best events in FRC".
Take from that last statement what you will.
Unread 09-03-2016, 17:28
TCMJ1816's Avatar
Peter
AKA: Peter Hartnett
You are totally right, I was more so looking at it as the cost per match as a second event. This obviously doesn't apply to most teams. That first $5000 is very worth it for all that it gets you, but the second $5000 is much harder to validate.
Unread 09-03-2016, 17:32
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
Subsequent regionals cost $4000, but that's still a lot.
