Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
  #61   Spotlight this post!
Unread 09-03-2016, 18:12
Bob Steele's Avatar
AKA: Bob Steele
Re: Team Update 15 (2016)
There are really only two solutions to this issue and unfortunately the decision has been made to do something that is not one of them
1st solution... use a different fabric in the same configuration
We all designed for fabric... with a pipe at the bottom.
2nd solution (which has already been implemented) is to remove the fabric and pipe altogether.
I am not really sure what the purpose of now coming up with something completely different is. It will end up with different issues... I find it hard to believe that zip ties will not break in this iteration.
I understand that we all need to adapt and be able to react etc etc.... blah blah blah real life... blah blah
but FIRST needs to do that also... come up with a change which is neutral for teams....
I honestly don't think our design will be compromised but I saw several robots last weekend that this design could be trouble for.
  #62   Spotlight this post!
Unread 09-03-2016, 18:14
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Has any one thought of the possibility of static charge/discharge ?
  #63   Spotlight this post!
Unread 09-03-2016, 20:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not until now, but that's an awesome idea! We'll mount a Van de Graff generator, charge the chassis up to about 40kV, and the vinyl flaps will never touch the robot!
Rules Check: Oh well, even if we didn't have a circuit to run the generator, there's another idea that's run afoul of R9.
  #64   Spotlight this post!
Unread 09-03-2016, 21:16
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Originally Posted by Lil' Lavery View Post
Based on what has been happening at work for me today, I don't think I can agree with you.
I will agree, I am usually the one who is changing requirements on suppliers - they usually charge me a lot for it. The difference is I can't bill FIRST for any redesign required.
Originally Posted by Jessica Boucher View Post
I guess this stuff doesn't phase me anymore. The only constant is that FIRST changes their mind. If I can recommend anything, the best use of your limited resources is to adapt and move on.
In FIRST changing software is essentially free. Mechanical redesign is not. Also code doesn't weigh anything (At least I think - I'm not much of a code guy)
Originally Posted by IKE View Post
We did go back an work with teams to make their leading edges more friendly, and this helped greatly, but did not fully resolve the curtain issues.
As a team that destroyed a piece of low bar fabric at Waterford (and paid for it by being disabled the entire match because our arm was stuck in it) I can safely say that I was surprised at how easily this fabric ripped. Unfortunately this may be disastrous for teams that planned on spinning up their shooter before they entered the low bar.
So who is going to suck a low bar flap into their shooter this weekend so we can get another rule change?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
  #65   Spotlight this post!
Unread 09-03-2016, 21:27
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Can I just go on the record as wishing FRC wasn't as annoying and frustrating as my day job can be?
  #66   Spotlight this post!
Unread 09-03-2016, 21:52
dradel's Avatar
That one made me smile from ear to ear Gee!!!
  #67   Spotlight this post!
Unread 09-03-2016, 21:55
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
I know its probably too late, but, crazy thought...
Kevlar is a fabric. Kevlar doesn't rip. I mean, you even need special scissors to cut the stuff. Why not kevlar? Expense and time, I suppose.
Why not Zoidberg for that matter? (Its a lame meme reference, I know, but this thread felt like it needed it.)
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
  #68   Spotlight this post!
Unread 09-03-2016, 22:08
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
As far as fabric goes, they should have used fabric with Twaron. We received some years ago from a sponsor and we did use it for bumpers. Mind you, it dulled our tin snips cutting it but it's really puncture proof. More here: http://www.warwickmills.com/Twaron.aspx
And for all of you who have a whole day at your next regional for the unbagging and flap mitigation time, you're ahead of us. We're going to our second district event which starts on Friday evening. And because we've been on top of things, not really expecting FIRST to give us a new design challenge, we have only two hours left of our unbagging time. We will have the practice and set-up time on Friday evening (5-10 pm), but we'd been really intent on using it for practice matches.
Life is never dull!
  #69   Spotlight this post!
Unread 10-03-2016, 06:05
GaryVoshol's Avatar
Cogito ergo arbitro
No, that's the Week 3 update when they change to Regolith.
(since 2004)
  #70   Spotlight this post!
Unread 10-03-2016, 11:08
Anyone see a drawing for change yet?
  #71   Spotlight this post!
Unread 10-03-2016, 11:50
bobl bobl is offline
FRC #0058 (The Riot Crew)
bobl will become famous soon enough
Cool! We'll get to see Dean walking around the field between matches with a bottle of anti-static spray again. Those of us who were at the '09 Granite State Regional will remember this well.
  #72   Spotlight this post!
Unread 10-03-2016, 15:49
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
There's a story here...
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
  #73   Spotlight this post!
Unread 10-03-2016, 16:04
I remember!
  #74   Spotlight this post!
Unread 10-03-2016, 16:05
As for the drawings question, I called FIRST about a half hour ago and the person who I spoke with did not know of any released drawings. She also did not know when the drawings would be released. Anyone have any more information?
  #75   Spotlight this post!
Unread 10-03-2016, 16:07
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Here is a picture of the new flaps.
http://www.chiefdelphi.com/forums/sh...d.php?t=145530
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
