Go to Post I thought Will.I.Am was a Dr. Seuss character - DonRotolo [more]
Unread 09-03-2016, 19:52
djperry1009 djperry1009 is offline
djperry1009 is a jewel in the roughdjperry1009 is a jewel in the roughdjperry1009 is a jewel in the rough
Re: Favorite Matches from Every Event
Originally Posted by Wert3141 View Post
2046 did something similar with a harder defense set in Quals 78. https://www.youtube.com/watch?v=TE4-po-QEbo
Yes, but the beauty of 1983's breach was that they completed it with 62 seconds left, climbed the tower, and won. I appreciate the self-breach but I think these robot performances were quite different.
Unread 09-03-2016, 21:28
Wert3141's Avatar
Wert3141 Wert3141 is offline
PNW Volunteer
Wert3141 is an unknown quantity at this point
Definitely some impressive stuff from both teams. Not trying to discredit any teams, a 60 second breach is very impressive. I just wanted to put out another instance of a team with two dead robots breaching. Also had 2046 scored that initial auto point they would have tied 1983's solo score.
Unread 09-03-2016, 21:46
Jcarbon Jcarbon is offline
FRC #3322 (Eagle Imperium)
Jcarbon has a spectacular aura aboutJcarbon has a spectacular aura about
Originally Posted by 3175leheh View Post
My favorite from Southfield 2016 was Quals 78
https://www.youtube.com/watch?v=hjoIGZCB3Xo
You guys were great in that match! That was the furthest a team has ever jumped up in my pick list in the last qualification match.
How do you line up for a shot? Do you have a camera? What were you working on during the competition to get it tuned up?
Unread 09-03-2016, 22:03
Wes2443's Avatar
Wes2443 Wes2443 is offline
AKA: Wesley Sakutori
FRC #2443 (Blue Thunder)
Wes2443 is an unknown quantity at this point
Originally Posted by Tmeziere View Post
San diego finals match 3
https://www.youtube.com/watch?v=YwGveI4IXX8
Blue alliance won by 5 points. Would have been a tie without fouls.
I definitely agree. This was an amazing match, probably the best I've seen since it was so competitive. It literally went down to the wire where we made it on the batter at the last second and the announcer thought Blue Alliance won. It was a thrilling match and honestly honored to be a part of it, even though we did lose by the smallest of margins.
Unread 09-03-2016, 22:19
Ro`bear Ro`bear is offline
3238 Program Manager
AKA: Robert Verdoes
FRC #3238 (Cyborg Ferrets)
Ro`bear is an unknown quantity at this point
My favorite match so far has got to be Q67 of PNW Auburn Mountainview. We, 3238, were down one robot on our alliance and in one match managed to complete six crossings and make six shots in the high goal. Even after that we only managed to win by 4 points with a shot and park in the last 5 seconds of the match after fumbling with the ball for a bit.
https://www.youtube.com/watch?v=SMFQ0314TJw
Unread 09-03-2016, 23:24
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Thanks for the compliment! For lining up for the shot, we have a Microsoft Lifecam that is lined up so that the top 'prong' of the shooter is virtually in the center of the picture when it is lining up, so we know exactly where to shoot it. We are working on getting our cycle time down, as sometimes it takes 20 seconds to line up, which has a lot of room for improvement.
For what we were working on during competition to get it 'tuned in', it basically required fixing the structure of the shooter. The bottom 'prong' that basically points to the true location of where the ball should go (the top prong is just for aesthetics) got bent slightly down in one of our early qualification matches. This was because we hadn't tuned in the flow control fittings correctly on our shooter lift piston (we have a two position shooter, one up position for shooting and one down position for intaking), which meant that the shaft collar that stopped the shooter from going down too far was getting pushed further down until the shooter was scraping on the ground. We didn't have a long enough of a break to fix the problem during quals on Friday, so after the last match, we worked to get it back into place and added a stronger corner bracket to make sure it wouldn't happen again. Once that was fixed, on Saturday, we actually were 100% at getting the ball to go into the goal. It did, however, come out of the goal twice during the first quarterfinal match.
I would also like to add my own contribution to the thread. There are two matches that stand out to me as being very exciting matches, even though one of them shows a little bias from me.
First, I would like to nominate SF 2-1. There was a dual breach, dual capture, which was the only time this happened during Southfield.
Second, partially due to personal bias, partially because its an exciting match to watch, I would like to nominate QF 1-2. This match came down to one boulder, even though the score may not show it. The 8 alliance needed one more boulder to capture, and when the match ended, behind the glass, I thought we had won the match. However, when the score came up, we found out that the 1 alliance had captured, which meant that we had lost. We had alumni who had been watching the webcast calling us because they thought we had pulled an upset. If you look at Dan Ernst's photos from the event, you can see our exact reaction when the score came up
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 10-03-2016, 01:11
Chief Hedgehog's Avatar
Chief Hedgehog Chief Hedgehog is offline
FRC #4607 (C.I.S.)
Chief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond reputeChief Hedgehog has a reputation beyond repute
This was the 2vs7 Quarterfinal in Lake Superior.
https://www.youtube.com/watch?v=Yuo3d4ewS0g
We knew that Nevis 3102 could knock out the defenses on their own as could Esko 5690 (for the Red Alliance). So it came down to us (4607) playing defense versus 2052 KnightKrawler. They put Fridley (2227) on anti-defense and it worked. We struggled to stop 2052.
A little history on 4607 and 2052: In 2013 at the MN state championships 2052 and 4607 were on the same alliance when we won the banner. In 2014 at state 4607 led the alliance against 2052, 2175, and 4778 in the state finals and lost. Later that year (2014), 2052, 1816, and 4607 teamed up to win MRI.
At Lake Superior 2052 and 4607 were in the same section and the noise was deafening. We have strong connections with 2052 and we respect them as much as any team. We also work well with 5690 - their alliance captain. So when we were paired against the both of them - it was bittersweet. In the heat of getting ready, we wound the winch the wrong way and could not climb. We lost that one - climbing wouldn't have mattered.
Regardless, this was one of the best matches I have seen for defense.
"An error does not become a mistake until you refuse to correct it" ~JFK
Unread 10-03-2016, 01:31
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
If we had stayed on the batter we would've had a capture and won. Did I ruin the match for you? I can't watch that one.
It was some solid defense. We essentially turned the eventual finalists into an alliance with only 1 scoring robot. 2052 was the only one getting boulders in the tower. Right strategy, but broken robots have a tendency to influence matches.
Bison Robotics President
35 new FRC volunteers from Bison Robotics
The GreenHorns Project Lead:
Reveal Video
White Paper
Unread 11-03-2016, 11:17
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
They were great matches for sure and our alliance got a bit lucky to escape quarters... I was bummed after we knocked you guys out during quarters because the alliance of 2526, 3102, and 4607 was well built and could of done some serious damage throughout eliminations. Good luck at North Star 4607 CIS! You guys have done great things throughout the MN FRC community and I hope our connections between teams stay strong!
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 11-03-2016, 11:43
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
I think if we played 100 matches with those alliances it would be 50-50. By far the most competitive alliance matchup in the Lake Superior Playoffs.
Reveal Video
White Paper
