Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 03-10-2016, 07:33 AM
sagrossm sagrossm is offline
AKA: Sam
FRC #5712 (Hemlock's Gray Matter)
Rookie Year: 2016
sagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to allsagrossm is a name known to all
Re: How to program Talon SRX Encoders?
I believe you can set the number of counts per revolution if that's what you're looking for. just use
motor.configEncoderCodesPerRev(insert desired counts per rev)
