You make my motors hot!
  #31   Spotlight this post!
Unread 19-02-2016, 16:02
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: NVIDIA Jetson TX1
Originally Posted by bhsrobotics1671 View Post
We have the same question. The box shows it's rated for 5.5-19.6v. We were having some issues running it on 12v last night. Just curious to see if other teams have found another solution already?
It will run off of 12v. It will run down as low as ~6V without causing serious performance issues.
We have yet to solve the issues with the TX1 and how sensitive it is to voltage fluctuations. The board will power down at the slightest breeze of a voltage drop from our experiments... we're actively investigating workarounds.
  #32   Spotlight this post!
Unread 19-02-2016, 16:13
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
Yeah, seems to be the issues we are having. In your testing does the TK1 work fine with no issues?
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
  #33   Spotlight this post!
Unread 19-02-2016, 16:17
Originally Posted by Nemo View Post
How does one deliver 19V power to a TX1?
Edit: Better question: how low can the voltage go and still run the TX1 development kit?
We have used these to boost our battery supply voltage for voltage sensitive electronics. http://www.amazon.com/DROK-Automatic...rds=buck+boost
Not sure of the power specs on the TX1, but it seemed to work well with the TK1.
  #34   Spotlight this post!
Unread 19-02-2016, 16:23
Andrew Nabors
AKA: Andrew Nabors
Thanks Tom!
I'm assuming there are no rules preventing the use of this on the bot for competition that you are aware of?
  #35   Spotlight this post!
Unread 19-02-2016, 19:40
lucas.alvarez96's Avatar
lucas.alvarez96 lucas.alvarez96 is offline
AKA: Lucas Alvarez
FRC #2576 (Chilean Heart)
lucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to alllucas.alvarez96 is a name known to all
Has anyone made or has a CAD of a case for the TX1? We're going to use the board on our bot and decided that the necessary protection is a must.
FRC 2576 2015-2016: Mentor
FRC 2576 2013-2015: Programmer & Chairman's Presenter
Los Angeles Regional 2014: Regional Chairman's Award
  #36   Spotlight this post!
Unread 19-02-2016, 21:41
Andrew Nabors
AKA: Andrew Nabors
We have it still mounted to the black board it comes mounted to, then we mounted that with brackets that are riveted onto that board with a piece of lexan guarding it. I'll see if I can get a picture later, but for us we did nothing special.
  #37   Spotlight this post!
Unread 20-02-2016, 00:59
marshall's Avatar
Enjoy: http://www.thingiverse.com/thing:1217209
  #38   Spotlight this post!
Unread 20-02-2016, 01:40
AKA: Lucas Alvarez
After 3 hours struggling with the massive STP file of the TX1 board supplied with NVIDIA and a laggy computer, I was starting to get something decent for 3D printing. Seeing this post and link has probably been the most bittersweet sensation during the season. Oh well.
No but really, thanks Marshall!
Would there be any negative effects if we mount the board upside down? I want to avoid having the hole for the fan exposed to the world (AKA metal shavings from last minute repairs on the robot)
  #39   Spotlight this post!
Unread 20-02-2016, 13:05
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
We ended up buying a 12V to 19V converter:
http://www.amazon.com/gp/product/B00M3SR51Y?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s01
I haven't dug into the rules closely enough to find anything that rules those out, but I suppose I'll do that while I'm studying up for robot inspecting.
We might end up using our mentor's TK1 instead. It's smaller, lighter, runs on 12V, and it talks to the cameras we bought unlike the TX1.
  #40   Spotlight this post!
Unread 08-03-2016, 14:53
marshall's Avatar
Have any teams had success with getting the TX1 powered via the robot?
I'm working on a write-up that describes what we have done and I can tell you it's not as simple as a 12v to 19v converter...
  #41   Spotlight this post!
Unread 08-03-2016, 15:40
Andrew Nabors
AKA: Andrew Nabors
Have you tried the buck boost that Tom linked?
  #42   Spotlight this post!
Unread 09-03-2016, 21:08
snekiam snekiam is offline
FRC #3322 (Eagle Imperium)
snekiam has a spectacular aura aboutsnekiam has a spectacular aura aboutsnekiam has a spectacular aura about
Is the TX1 significantly better for simple OpenCV hardware acceleration than a TK1? I am looking at how to get vision done for our team, and don't want to spend the extra money if we don't have to. Our original plan was to use a raspberry pi, but the processing power seemed to just be too low.
  #43   Spotlight this post!
Unread 10-03-2016, 08:25
marshall's Avatar
We tried similar without any luck... The TX1 really wants a constant voltage.
We were able to get some help from Nvidia and the following modifications to the the TX1 actually seem to work nicely:
https://devtalk.nvidia.com/default/t...24595/#4824595
We now have the makings of a TX1 on our robot with something special in store for keeping it powered that I'm sure is going to draw some looks from inspectors. More details to come after our upcoming event.
Yeah, this board is not for you. The TK1 is definitely better in terms of CPU/GPU power than the Pi but honestly, stick with the Pi and the basic examples until you get them working then move on from there.
  #44   Spotlight this post!
Unread 10-03-2016, 10:52
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Which change did you do? Disable the circuit or change the capacitors?
I think we are just going to stick with the tk1 this year.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
  #45   Spotlight this post!
Unread 10-03-2016, 11:00
marshall's Avatar
We changed the capacitors.
