Go to Post How are you planning to teleport balls? Or your robot? I was pretty sure that the battery couldn't supply the required power draw. - RoboChair [more]
View Poll Results: Type of scouting
Qualitative above Quantitative 13 23.21%
Equal weight 21 37.50%
Quantitative above Qualitative 22 39.29%
Voters: 56. You may not vote on this poll
Unread 10-03-2016, 12:08
Why_A_Username?'s Avatar
Why_A_Username? Why_A_Username? is offline
AKA: Jacob Pilch-Bisson
FRC #2910 (Jack-In-The-Bot)
Team Role: CAD
Rookie Year: 2015
Why_A_Username? has a spectacular aura aboutWhy_A_Username? has a spectacular aura about
Scouting: Quantitative vs. Qualitative Poll
I am leading our team's scouting operation this year, and although we have a system in place, I was just wondering how other teams rank quantitative (number data) scouting with qualitative (mission agreement and personal disputes, as well as observed tactics). Please answer the poll and feel free to discuss results.
Currently we rank them equally, if not slightly leaning to qualitative.
"I don't remember how to make that! It came to me in a dream, and I forgot it in another!" -Professor Hubert Farnsworth
"The only difference between science fiction and science is time"
-Dean Kamen
Unread 10-03-2016, 12:20
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Scouting: Quantitative vs. Qualitative Poll
The problem with quantitative scouting is that it's prone to suffering from "garbage in, garbage out" while simultaneously looking trustworthy and reliable.
We humans have a tendency to give undue weight to numerical values simply because they are numerical values, without really putting much thought into where they came from and how meaningful they actually are. In my experience, I've found that, at least in FRC, qualitative impressions of a robot are quite a bit better than attempts to quantify performance.
Granted, there are some useful numerical scouting tools. OPR works reasonably well for offense in many games, for example. However, there's simply so much information that is clear to an astute observer that can't be easily quantified, and throwing it out simply because you can't quantify it is unwise.
"The breakfast of champions!"
Unread 10-03-2016, 12:30
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
..and from a statistical perspective not enough sample size either.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 10-03-2016, 12:32
AKA: Eli Barnett
This is a big part of what constitutes "garbage in," yes.
Along these lines, there are some very interesting cognitive science results that suggest that people make better judgments with extremely limited data sets when they rely on heuristics and intuition rather than explicit utility calculations. This is unsurprising, as the act of formalizing one's reasoning in that way often greatly restricts the body of evidence that you're actually using (since you only end up taking into account those things which you explicitly quantify), even if you're not aware of it. While in situations where you have large amounts of data this drawback is hugely outweighed by the benefits, when you're stuck with little information to begin with it can (and does) do more harm than good.
Unread 10-03-2016, 12:43
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
If you know what sort of robots you are looking out for, quantitative data is very useful. Like most topics, however, a mix of the two will probably lead to the best results.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 10-03-2016, 12:45
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Depends whose qualitative impression, though. It is easy to find people to record simple statistics of one robot per match. It is very much harder to find people that can identify strengths and weakness of robots and remember them for a big chunk of the teams at an event. Outside the top handful of teams at an event, I'd bet the average scout couldn't tell you much of anything for around 50% of teams.
Unread 10-03-2016, 13:16
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
My team is looking at Quantitative results mostly strictly to determine what defenses we should put out against any given robot(s). Qualitative and Quantitative combine for our internal rankings of the robots as far as eliminations.
Make sure that if you are focusing on your quantitative data, you keep track of their partners and opponents. It can skew a team's trend if they are the middle of the pack team doing all the work for two bottom-quarter robots or if they are the "cheesecake" to 2 extremely highly efficient teams, or if they face the "best" defensive team at the event.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
