Go to Post Pro: Very easy to build with. Con: HEAVY AS ELEPHANTS - Tetraman [more]
Unread 22-02-2016, 15:45
charles.miller charles.miller is offline
FRC #4521
charles.miller is an unknown quantity at this point
Question Bumper rules clarification
We have waited until the last two days to create our bumpers... in years past, there has been a rules stating that the connections between the bumpers and the robot frame must be, at most, eight inches apart. This year, however, we could not find such a rule. We are wondering if anyone has an answer to our problem. Thanks!!!!!
Unread 22-02-2016, 15:52
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Bumper rules clarification
As long as there is no more than a 1/4" gap between the frame and the bumper backing, you may have more than 8" of "unsupported" bumper.
...unless I've totally misread the following rule and associated Figure.
R26 BUMPERS must be supported by the structure/frame of the ROBOT (see Figure 4-9). To be considered supported, a minimum of ½ in. at each end of the BUMPER must be backed by the FRAME PERIMETER. Additionally, any gap between the backing material and the frame:
A. must not be greater than ¼” deep, or
B. not more than 8 in. wide
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 10-03-2016, 10:21
serenagh serenagh is offline
Student
FRC #3045 (Gear Gremlins)
serenagh is on a distinguished road
Clarifying question on "backed by" - must all (5") of bumper plywood be touching metal structural elements? Would a 1" rim be enough? In the diagrams, it doesn't seem like there are continuous metal pieces on the frame, and the frame perimeter is also defined by an upward projection).
Team Captain & Founder: FTC #7593, TigerBots
Team Captain: FRC #3045
Unread 10-03-2016, 10:37
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Per the rules, I don't see any reason it wouldn't. However, given the intended function of the bumpers, (provide protection in collisions) I would recommend significantly more backing. For example our bumpers this year only have about 1" of overlap with the KoP chassis, but we added some 4" steel angle brackets on the front and rear and some aluminum side plates that reach above the bumpers on the left and right.
Unread 10-03-2016, 10:40
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Based on our "passed inspection" robot the answers to your questions are NO and YES. Don't skimp on your bumper fabrication. In this game they take a beating.
More pics.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 10-03-2016, 10:49
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
There is no specified minimum. So theoretically it could be a knife edge. But it needs to be "robust" which is a judgment call. We routinely use 1" box channel for our frame perimeter. That has never been questioned.
There is also a 1/2" minimum on the corners. Once again that is linear and an area.
As others have said: It to your advantage to make sure your bumpers are roboust.
Unread 10-03-2016, 14:12
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
There is no rule this year that mandates attachment points. The rule is what is behind the bumper.
In theory, you could have pillars every 8 inches to "back" the bumper, and have only one attachment point. It wouldn't be very robust, but that is the team's choice.
Unread 10-03-2016, 16:41
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I think that theory would break the rules:
R21g: must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form
a tight, robust connection
to the main structure/frame (e.g. not attached with hook-and-loop,
tape, or tie-wraps). The attachment system must be designed to withstand vigorous game
play.
So not really a choice.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
