Go to Post Please drill responsibly! - IKE [more]
Unread 10-03-2016, 14:04
ahaltom ahaltom is offline
FRC #5712
ahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of lightahaltom is a glorious beacon of light
Scaling Winch Motor Help
Hi,
I'm looking for a bit of guidance regarding the motor(s) that we will be using for our scaling mechanism.
Our plan is to have a scissor lift reach up to the pull up bar and a winch to lift the robot. I imagine the motor(s) attached to the winch will need to be quite powerful considering the robot will weigh a bit over 100 lbs. Does anyone have suggestions as far as type of motors, gear ratios, etc.?
I saw one post from a couple of years ago about attaching two CIM motors to a gearbox, but wasn't sure if this was the best way to do it or not.
Any help would be greatly appreciated.
Thanks,
Alex
Unread 10-03-2016, 14:22
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Re: Scaling Winch Motor Help
We prototyped using 1 cim through a 5:1 versaplanetary gearbox and then through a 12.75:1 toughbox nano with a ratcheting mechanism to stop backdrive on a 1.5" Dia spool.
Whole thing is ~9"x5"x2.5" works great.
Overall gear ratio (63.75:1)
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 10-03-2016, 14:27
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is online now
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
I see you plan on making a similar system to ours.
we had a single 775 from vex at first. i believe geared down 75:1
we doubled that at GTCR, now 2 775s, same ratio.
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 10-03-2016, 14:39
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Principles first:
Let's say your task is to lift 150 pounds 36 inches in 5 seconds. The mechanical power required is 150 x 36 / 5 = 1080 inch-pounds per second.
Inch-pounds are converted to Newton-meters by dividing by 8.85, which gives the required mechanical power as 122 Newton-meters per second. This unit is also called a Watt.
122 Watts mechanical output is well within the capability of a CIM motor, so an efficient (low friction) lift mechanism could climb higher than 36 inches, or in less time than 5 seconds, or some combination of the two.
Richard Wallace
since 2003
Unread 10-03-2016, 14:48
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
In addition to everyone else's replies, two PG71 gearmotors will also do the job quite nicely. We're driving the winch with those, no further reduction.
Just remember that the diameter of your reel does affect the torque and speed of the lift!
Unread 10-03-2016, 15:09
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
As Richard indicated, the real question is: how fast do you want to lift? Once you know your speed target, you can work backwards to figure out how much mechanical power you need from your motor. Personally, I always leave in an extra factor of about 50%, since there's friction in the gearbox, weight estimates might not be perfect, and your battery state at the end of the match probably isn't great.
My team has lifted our robot before using a single CIM motor one year, and two mini-CIMs another year. This year, it's two CIM motors, based mostly on availability and not needing them elsewhere - we'll take all the speed we can get while climbing!
2016: Lake Superior WFFA
Unread 10-03-2016, 15:55
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
I strongly recommend the JVN Mechanical Design Calculator.
Unread 10-03-2016, 16:13
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
We use 2 Full CIM + Toughbox...tested it to well over 100lbs
Winches up bot in 6 seconds to necessary height after hooking the bar
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 10-03-2016, 17:50
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Go to the linear motion tab, and put in the variables that you would like such as distance of raising, speed of raising and pulley size. It will help you identify the type of motor(s) that you will require and the gear reduction you will need to ensure adequate torque.
If you need help or you want me to double check your calculations just PM me
Unread 10-03-2016, 21:02
DonRotolo's Avatar
Back to humble
FRC #0832
See all the above first.
Next, you should consider some kind of winch system. The smaller the 'spool' the greater the mechanical advantage, while larger spools will wind more material per rotation.
With a winch you want to prevent back-driving, the tendency for the weight to let the spool unwind when unpowered. But remember you need to be able to get the robot down, eventually.
The 'rope' you use needs to be more than 2x as strong as necessary. A 300 lb breaking strength is not, in my own opinon, safe enough.
Look up the term 'fairlead' as it applies to winches, and consider using one.
Lastly, remember that if your robot turns sideways (wheels against the tower), your 'hook' will be more than 15" outside your frame perimeter, which is a problem.
Good luck!
Unread 10-03-2016, 21:52
Tmeziere's Avatar
Tmeziere Tmeziere is offline
AKA: Tim
FRC #3021 (The Agency)
Team Role: Driver
Tmeziere is an unknown quantity at this point
We are using a rack and pinion with a 30t gear.
775 pro with versa-planetary 7:1 gearbox then through a 20:1 worm gear.
total ratio is 140:1 and it is very fast. Also the worm gear keeps it from back driving
2016 Delmar~winners
2016 Utah-semi~finals
2015 San Diego~quarter-finals
2015 Arizona East~semi-finals
Unread 11-03-2016, 09:42
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
3506 is using a Mini-CIM on a vex versa planetary gearbox with a ratio of 63:1 on a 2" diameter spool. We realize most teams forget this but when the power to your robot shuts off you need a brake to keep your robot from back driving so we used a small pneumatic cylinder as a brake. It deploys into a cam attached to the winch spool shaft to stop the decent of our robot when the power shuts off.
We had the fastest and most reliable climber at the event with this setup but we did have a small failure on one of the sun gears that we are not sure about. It might have been overloaded, it might have been a defect but either way we had to take the gearbox apart and put a new stage in right before finals.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
Unread 11-03-2016, 11:01
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we are using all 4 of our drive motors with a PTO
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 11-03-2016, 12:03
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
We use a single 775 pro with a versa-planetary geared down to 125:1 (3 stages of 5:1) and it seems to lift the bot without any problems.
If you have concerns about the power or performance of the 775 pro you can easily use the same system with a mini-cim.
Unread 11-03-2016, 18:05
pilleya's Avatar
Elec+Mech
What size pulley are you using on that?
However the mini-cim is not a 1:1 replacement for the 775pro, although the 775pro is about 125 watts more powerful than a mini-cim the main difference is output speed the Mini-cim rotates at around 6000rpm vs the 775pro which rotates at around 19300rpm so about 3 times as fast, this means that if you were to use a mini-cim you wouldn't require such a large gear-reduction( but also take into account that the mini-cim outputs less torque vs 775pro geared to the same speed as the mini-cim)
