Go to Post In my line of work, we affectionately refer to this approach as "Seagull Engineering". Why? Because we swoop in, flap around making a lot of noise and commotion, leave a big mess of "stuff" behind and then fly off. - billbo911 [more]
Unread 11-03-2016, 09:00
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
WCP 0917 Hall Effect Sensor
I been looking at this board for a possible solution to home/reset an encoder position. Trouble I'm having is how to orientate the magnet to the board. I have found no installation instructions on the proper set up.
Where and how should the magnet cross the board?
Can I run this to a DIO pin on the RoboRio or do I need the WCP Spartan Sensor Board?
Unread 11-03-2016, 09:02
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: WCP 0917 Hall Effect Sensor
I'll let Austin answer the first two questions,
but our team uses these in a few places. Basically you treat it like a limit switch and can plug it into any DIO port. As the magnet crosses the black square in the CAD file it triggers. We sell a .5" diameter magnet but you can basically use any magnet you want.
Hope that helps
R.C.
MadTown Robotics Team 1323
