Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
View Poll Results: Are You Tracking The Goal To Help Shoot
Yes - And It Works! 133 49.63%
Kinda - We Are Working On It! 104 38.81%
Nope - We Are Not Using A Camera 31 11.57%
Voters: 268. You may not vote on this poll
Unread 11-03-2016, 18:24
Data Nerd
FRC #0079
Re: Are You Using A Camera To Align Their Shooter?
Originally Posted by ThomasClark View Post
That's really cool to hear. Do you have any suggestions for more feature refinement operations? If you open an issue and it doesn't look too hard, I can try implementing it.
Cool. One of GRIP's often overlooked use cases is actually a prototyping tool. For people who'd rather write their own OpenCV code for efficiency/portability/educational purposes, GRIP is still useful to lay out an algorithm and experiment with parameters.
1 - Or just send a single camera stream. If you're using SmartDashboard, you can publish the video from GRIP locally to the dashboard and use the GRIP SmartDashboard extension. Otherwise, I guess you could have the GRIP GUI open for drivers to look at.
2-4 are valid points, and running GRIP on a cheap coprocessor like a Kangaroo PC (or, like some teams have managed to do, Raspberry Pi) helps a lot.
I was actually playing with adding some stuff myself.
Update from AZ - GRIP seems to be running fine on our machine. Post event I'll see if I can get our vision kids to post a bit more detail.
