Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
  #31   Spotlight this post!
Unread 04-03-2016, 12:37
Stayskull Stayskull is offline
FRC #0948 (NRG (Newport Robotics Group))
Stayskull is an unknown quantity at this point
Re: FRC Spyder
What does DPR and CCWM mean or represent?
  #32   Spotlight this post!
Unread 04-03-2016, 12:43
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
Re: FRC Spyder
The Android app shows this blurb when you tap the '?' button at the top of the stats page; I'm not sure about iOS:
OPR (Offensive Power Rating) uses a mathematical model to estimate each team's contribution to their alliances' scores. Higher is better.
DPR (Defensive Power Rating) uses the same mathematical model to estimate each team's contribution to the opposing alliances' scores. Lower is better.
CCWM (Calculated Contribution to Win Margin) = OPR - DPR. A team's total contribution to their alliances. Higher is better.
The usefulness of these statistics varies by game; some years it's accurate, some years it's a novelty. It's up to you to decide how to interpret them.
  #33   Spotlight this post!
Unread 05-03-2016, 02:03
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
Re: FRC Spyder
DPR (Defensive Power Rating) uses the same mathematical model to estimate THE AVERAGE SCORE OF the opposing alliances' scores. WHETHER LOWER OR HIGHER DEPENDS LARGELY ON THE CHARACTERISTICS OF THE OPPOSING TEAMS IN THOSE ALLIANCES.
  #34   Spotlight this post!
Unread 05-03-2016, 21:44
Trying to Help Trying to Help is offline
FRC #1729 (Monadnock 4-H Robotics)
Trying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud ofTrying to Help has much to be proud of
Re: FRC Spyder
What a truly wonderful reason for unlimited data! Thank you for this app! Our team used it a ton today.
  #35   Spotlight this post!
Unread 06-03-2016, 16:17
Storcky's Avatar
Storcky Storcky is offline
FRC #3634 (Hard Botties)
Storcky is on a distinguished road
Re: FRC Spyder
The new Android version of the app requires Google Play Services... any chance of a BB10 friendly version? (although demand is not likely very high)
Thanks for all the work you do on this app!
Alum of 1629 - GaCo [2005-2008]
Mentor for 3634 - Hard Botties [2013-2015]
Mentor for 230 - Gaelhawks [2013-2015]
Pittsburgh Regional Planning Committee [2016-?]
  #36   Spotlight this post!
Unread 06-03-2016, 16:37
Software guy
Re: FRC Spyder
Google Play Services isn't actually required; it's only used to receive match score notices. The app should function correctly without it. I'll see if I can change the popup to only appear once so you don't have to dismiss it every time you open the app.
  #37   Spotlight this post!
Unread 11-03-2016, 19:37
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: FRC Spyder
Is it just more or are the rankings on Spyder not sorted by ranking points?
Got excited that 1675 was in 1st when they are actually in second.
  #38   Spotlight this post!
Unread 11-03-2016, 19:43
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: FRC Spyder
Most things seem to be confused. I looked at one team that had played two matches with 60 something points in each match that had an OPR of 120. Another team with 2-1 record had -30 OPR.
Predictions are generating negative scores.
  #39   Spotlight this post!
Unread 11-03-2016, 20:05
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: FRC Spyder
Sorry about that. It looks like this was caused by a defect in FIRST's API where they are not handling the If-Modified-Since header correctly. I disabled that header and now things are looking correct again - please let me know if you see further issues.
Predictions probably weren't right for a while there due to the above problem, but negative scores in the predictions aren't an indicator of any issue. Predictions are based on summing each team's OPR which means the predicted score can go negative when a team has a negative OPR.
  #40   Spotlight this post!
Unread 11-03-2016, 20:29
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Re: FRC Spyder
Negative or massive OPRs (and other ratings) are just the result of not enough data. In a statistic model with up to 60 variables (teams), It takes many data points (matches) before a useful solution is available.
In short: wait a dozen matches or so
  #41   Spotlight this post!
Unread 11-03-2016, 21:33
Re: FRC Spyder
Originally Posted by BBray_T1296 View Post
Negative ... OPRs are just the result of not enough data.
Not necessarily. If a team is really struggling, the OPR at the end of the event can be negative. There was a team with negative 10 OPR in Week1.
  #42   Spotlight this post!
Unread 11-03-2016, 22:06
I am Dave! Yognaut
AKA: Brian Bray
Re: FRC Spyder
You are right, if a team averages more penalties (In fouls or playing defense on their own teammates) then a negative rating can occur.
