Go to Post I'd just give you the URL, but then you wouldn't learn to look for yourself. - DonRotolo [more]
Unread 11-03-2016, 17:36
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
IP Camera at competition
Anyone have any idea why our ip camera worked in the shop but doesn't when tethered top the fms? Only 2 ports means we cannot test it very easily.
Unread 11-03-2016, 18:48
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
Re: IP Camera at competition
We had the same problem last week. We could work with the "home" firmware in the radio, but could not connect to the IP camera with the "competition" firmware. We resolved the problem by going to static IPs all devices. It is my understanding that several teams had to make this change. I don't know if all were having IP camera issues.
You can use last year's bridge (with WiFi disabled) as an on-board router for the robot. We used a spare VRM for power, connected the second output from the radio and the camera to the Dlink. You can then tether the DS and/or your development computer to the Dlink in the pits/practice field.
Unread 11-03-2016, 19:22
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
You can use the USB port to tether to the robo-rio to deploy code while tethered, I'm not sure about viewing the camera or running the DS while tethered over usb, but it's something you could look into.
2015 MAR District Champions
Unread 11-03-2016, 21:16
cmastudios's Avatar
cmastudios cmastudios is offline
AKA: Connor Monahan
FRC #1706 (Ratchet Rockers)
cmastudios is an unknown quantity at this point
My team had the same issue with the Jetson TK1 today as well and I can confirm that the above fix of assigning static IP addresses works for network communication with this device as well. I was informed by a FTA and found through observation that no DHCP server runs on the radio after configured for bridge mode.
Unread 11-03-2016, 23:47
AKA: Rich Lester
Static ip for us was half the battle. The final solution was to setup the hosts file to point axis-camera.local (or whatever it was can't remember to the new static ip. Then it worked.
Unread 12-03-2016, 00:00
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Yes, we did a static IP as well at our competition last weekend. Anything in the rang of 10.TE.AM.11-19 won't conflict with anything else that is used by FIRST, dhcp or static.
I program a robot. Which means I write code and everyone gets mad at me when something doesn't work, even if I am the only one that knows it doesn't work. The key part to know is that the robot never works.
Unread 12-03-2016, 01:40
waialua359's Avatar
AKA: Glenn
Yes, we were told to use anything from 11-19 also with no confiicts.
