Go to Post The only thing I am learning from this thread is the difference between who is arrogant enough to objectify their own interpretations and who is wise enough to question their own interpretations. - Michael Corsetto [more]
Unread 11-03-2016, 14:30
vigneshv vigneshv is offline
FRC #2489
vigneshv is on a distinguished road
AndyMark RAW Box and Potentiometer
Hi!
We're using an AndyMark RAW Box as the gearbox for our angle changer mechanism for our shooter, but we want to have a reliable way of determining the angle of the shooter, which will not depend on position at the start of the match (so preferably not an encoder, we're leaning towards using a potentiometer). Have any teams successfully attached a potentiometer to an AndyMark RAW Box, and how have you done it (or any gearbox with a threaded output)?
Unread 11-03-2016, 14:40
Knufire Knufire is offline
Re: AndyMark RAW Box and Potentiometer
Since the AM RAW box already has the encoder mount for the E4T, you might be able to add a limit switch or hall effect sensor somewhere else on the mechanism to give the encoder a reference point. This way, you can use the encoder for absolute position. We used this approach on our 2015 elevator and it worked perfectly.
Another option is to use the AM String Potentiometer and attach it to the base of your robot and the string to the mechanism: http://www.andymark.com/product-p/am-2674built.htm
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 11-03-2016, 14:49
FRC #2489
So would this be implemented by moving the mechanism towards the switch at the beginning of the match, and then resetting the position of the encoder to 0 when it reaches the switch (because as far as I understand the only information you can get from both limit switches and hall effect sensors is on/off)?
Unread 11-03-2016, 14:53
Exactly!
Unread 11-03-2016, 14:55
FRC #2489
Exactly!
Thanks, that sounds like it'll work!
Unread 11-03-2016, 15:17
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Watch speed and backlash.... That homing routine is ok for most FRC applications, in industrial servo systems, the homing routine is...
Advance toward switch high speed.
Trip switch,
reverse direction,
run slow,
release switch.
set zero.
This method puts the gear backlash behind you...
The direction you need to move off zero, the gears have already meshed to drive that direction.
Probably over kill if you only have the one gearset, but if you have multiple gears, the backlash adds up.
The sooner we get behind schedule, the more time we have to catch up.
Unread 11-03-2016, 15:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Trip switch,
reverse direction,
run slow,
release switch.
set zero.
You forgot looking for the index pulse on the encoder before setting zero.
Also, you might try adapting the e4p mounting for an SRX Mag Encoder You can use that in absolute mode. The mounting should be quite similar to the e4p, but you'll have to drill a hole in the shaft to put the magnet in.
Unread 11-03-2016, 15:47
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Hi!
You mileage may vary, but we had a raw box for our shooter arm angle (it also had the ball pickup on the same arm) and we destroyed a gear in the box at a week zero event. We've replaced the gearbox with a different solution and also lightened the arm somewhat.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 12-03-2016, 18:58
FRC #2489
Hmm, we haven't run into that problem yet, but what's the alternative you are using?
Unread 12-03-2016, 19:17
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
We switched to using a Toughbox Mini and running the motor parallel to the shaft instead of perpendicular, which gives more room for electronics as an added bonus. We've been having problems with sag, but we are using the encoder-and-limit-switch method described earlier in the thread, so we can use PID stabilization. It's also a slightly lower reduction, but still powerful enough, in conjunction with a 25:1 VersaPlanetary.
Our arm assembly was also very heavy at that point because it is an intake and shooter. We lightened the intake considerably after that event. Depending on the weight of your arm/violence of movement, a raw box may be sufficient.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 12-03-2016, 21:41
BeardyMentor BeardyMentor is offline
Just the right amount of Crazy
AKA: Matt Hagan
FRC #1257 (Parallel Universe)
BeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud ofBeardyMentor has much to be proud of
I will second the use of the SRX Mag Encoder. If you have access to a lathe, it is very easy to install and plugs right into the talon srx which frees up pins on the RoboRIO. a+ product so far.
