Go to Post It doesn't matter what material you pick, it matters how you execute your design. - JamesCH95 [more]
Unread 12-03-2016, 23:40
Hellothere33 Hellothere33 is offline
FRC #5444
Rookie Year: 2015
Hellothere33 is an unknown quantity at this point
Re: publish video on Kangaroo with Grip
Great job Scott for the detailed explanations and thank you very much sharing!
Unread 25-03-2016, 11:29
FRC2501's Avatar
FRC2501 FRC2501 is offline
FRC #2501 (Bionic Poalrs)
FRC2501 is an unknown quantity at this point
s-taylor, your doc was very helpful to our team this year in getting our GRIP and Kangaroo to work.
"It might be possible to VNC in from another computer already on the robot radio wireless network, but we never got around to trying that. Hmmm…"
We were able to do this, but we had to set the Kangaroo to a static IP on the network.
We were wondering if there was any way to get the GRIP image that we published to show up on the SmartDashboard. It seems that the GRIP output viewer requires that you have a solid frame rate, yet the frame rate on the GRIP is nowhere near solid (fluctuates from 20 to 30). The image only shows up when the frame rate from GRIP and the smartdashboard are the same.
Unread 07-04-2016, 11:36
s-taylor s-taylor is offline
Scott Taylor
FRC #1735 (Green Reapers)
s-taylor has a spectacular aura abouts-taylor has a spectacular aura about
We never pursued the final use of the GRIP SmartDashboard extension that ThomasClark posted earlier in this thread.
Our driver decided in the end that looking down at a live video feed was more distracting than maintaining continuous focus on the playing field, so we never finished that aspect of the system.
However, if you are seeing issues with the use of that extension, I'd contact Thomas and see if it's a configuration issue or an "architectural" divot that could be addressed. Definitely re-post if you find any workarounds, and I'll add that to my document!
Last edited by s-taylor : 07-04-2016 at 11:38. Reason: The Department of Redundancy Department needed to be cut out of the editing loop
Unread 09-04-2016, 20:04
FRC2501's Avatar
Our team found the input from the camera to be very useful for driving, especially when we were behind defense like the drawbridge, picking up a ball or lining up for a cheval run.
Our solution for the competition was to have 2 cameras, one on the kangaroo and vision filters, and one on the RIO that displayed on the driver-station.
Unread 10-04-2016, 14:53
Scott Taylor
Oh, I personally agree with you, and your suggestion is exactly what *I* would do if I was the driver. But I'm not. :-)
Sometimes, you just have to let the students do what they think is in their best interest and let them loose on the field...
