Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
Unread 13-03-2016, 14:05
gordmaier gordmaier is offline
FRC #4917
gordmaier is an unknown quantity at this point
Ball / Boulder Consistency
In practice we are seeing significant performance variation in shooting "well used" boulders vs newer ones. Our first regional is next week so we're looking for some feedback from those of you who have competed re: how consistent/new/used/banged up are the boulders at a competition. Are they getting worse week by week, are they starting with new ones... any feedback appreciated. Thanks
Unread 13-03-2016, 14:10
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Ball / Boulder Consistency
There's some that stay perfect, even into elims. Others are so banged up that they're visibly smaller than the others, even from the stands.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 13-03-2016, 14:13
Chris is me's Avatar
AKA: Pinecone
Boulders get more torn up than I ever expected before they are removed. More than once I was given a boulder with a chunk missing from it to pre-load for autonomous. Boulders get under robots, into mechanisms, jammed in defenses, lots of opportunity for them to become jammed.
For a wheeled shooter, getting consistency is quite tricky, and I would start by increasing compression as much as you can. It seems the more you squeeze a ball, the more consistent the shot from ball to ball. Your mileage may vary.
Unread 13-03-2016, 14:16
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
We ran into some problems with boulders worn differently than were expected. We had 3 different wear boulders we tested our shooter with, however, none of them were torn. Many of the boulders (at orlando at least) would remain in play even with 7-8 inch gashes in them and at least 1 cubic inch holes of missing material. It took sifting through almost every ball on the field to find one that I would be comfortable preloading each match.
If the boulders were significantly damaged they would duct tape them back together. They held together but between the gashes and the different surface material many of our shots ended up missing low.
We've got a heavily damaged ball now to see if there's a way we can adjust for rocket city but it made shooting in Orlando much more difficult than anticipated.
2012 - Engineering Inspiration SFL
2013 - Chairmans SFL, Regional winners SFL
2014 - Engineering Inspiration SFL
2015 - Chairmans GSCR
2016 - Chairmans Rocket City Regional
Unread 13-03-2016, 14:20
FRC #4917
Do they start with a fresh set at each regional, or are they progressively getting worse?
Unread 13-03-2016, 14:22
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Hope your shooter has variable compression. We ran into boulders with tape towards the end of quals.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
