Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 13-03-2016, 15:59
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: The Chokehold Strategy of 2016?
Originally Posted by Rangel(kf7fdb) View Post
Can be a pretty effective defense but I don't really see it as a chokehold. Especially since the defending robot has to drive in an arc around the secret passage while the red robot could turn 45 degrees from where it is at now and simply drive forward or back depending on position of the depending robot. Red robots could also work together to keep the defense on one side of the arc. I know at Arizona North, 2122 was pushing robots trying to block team 125's vision.
If you have a robot herd a boulder out of the secret passage and in running your plan push that boulder back into their secret passage I believe that is a foul.
The current meta doesn't involve teams diving into the secret passage for balls when the human player can bowl them into the neutral.
So yeah the strategy would kinda work but it isn't a choke hold. And as stated before you got G21 flipped around. If you ran this you would actually pull fouls because a robot has the right of way in their own secret passage in regards to an opposing robot.
Also I'm agreeing with Rangel if that isn't clear dude knew his bidnizz in Arizona North
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
#GLITTERFORCEHYPE!
Play is for kids this is serious...
Unread 13-03-2016, 16:54
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
All I can say right now is that it is challenging to pull off without drawing penalties, but still definitely possible.
It's not a chokehold, per se, because if your opponents know how to react to it, they can still get boulders - albeit much slower.
You need to make sure your team playing defence knows exactly what is allowed and what isn't, which is difficult to convey during Saturday lunch, without ever having practiced it.
You also need to invest the time in explaining to the refs what you are doing so they are going to call it as expected. Some things can be subject to interpretation.
Are you allowed to position yourself at the end of the opponent's SP and let opposing boulders bounce off you so they stay in the SP? You definitely should.
Should you be able to play defence in the neutral zone to prevent your opponents from getting balls that are outside the SP? Yes, of course, but if there are balls near the opening of the SP that you are defending, things get murky.
I also agree that you should be able to box opponents in to their own SP based on how the rules are currently written.
You need to tell the refs exactly what you expect to happen as well... and what penalties should be called in what circumstances.
Our attempt in SF2-1 at GTRE was not really well executed, but enough to prove the concept and learn how to improve on it. We held the opponent to 6 boulders scored, but there are a lot of penalty calls, so it's still very debatable. It wasn't a very close match when you see all the penalties.
I think it will catch on more as the weeks go by, however. Not too many will try due to the penalty potential, but those who can successfully do it will be able to pull some upsets. It might be interesting to see 2nd picks at Champs focused on teams who can play defense in this way effectively.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 13-03-2016, 17:36
gp2013 gp2013 is offline
FRC #2013 (Cybergnomes)
gp2013 will become famous soon enoughgp2013 will become famous soon enough
Fair enough. I think all three alliance teams would need a significant amount of FRC experience to get those things to align (esp. convincing the referees) but there are many teams out there with that experience and at world's we will see them. I certainly would consider using it (or a variation of it) again (though I am waiting for the GTRE videos to go up online to review it) especially in a situation where we are facing a much stronger alliance. I do agree that we will see this defence run again as the season progresses.
Unread 13-03-2016, 19:12
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
How doesn't this violate G11?
G11: Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of
FIRST Robotics Competition and not allowed. Rule violations forced in this manner will not result in
an assignment of a penalty to the targeted ALLIANCE.
Violation: FOUL. If egregious or repeated, YELLOW CARD
Unread 13-03-2016, 20:43
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Because it doesn't force anyone to take any penalties.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
Unread 13-03-2016, 22:00
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
G43 has nothing to do with preventing robots from traversing their own defense. It only says you can't contact the opposing robot in your own Outerworks. But you can still traverse them yourself (Alliance 4's defense robot drove through their Sally Port during the last 30 seconds of the match when they were facing Alliance 1 at Lakeview and received no penalties).
Therefore, no chokehold.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2016: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 13-03-2016, 22:06
Edxu's Avatar
Edxu Edxu is offline
Scouting/Strategy Lead
AKA: Edwin Xu
FRC #0610 (The Coyotes)
Edxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud ofEdxu has much to be proud of
However, if they touch you while YOU'RE in their defense, they get a penalty. They are penalized for violating rule G43, as you are parked in the defense that they try to cross. G43 does not cover a robot stopping an opponent from trying to cross their own defenses.
2013 FRC World Champions (1477, 1241, 610)
Queens University Computing Class of 2020
6-??
